- 8 Jan 2003
- Scotland
That's a lot higher than I get with a Ryzen 5 2600. I idle at 37'C-42'C, and just ran a few benchmarks (CPU stress test + TW:WH2 & FH4 benchmarks) to check load temps. Topped out at 62's. That's with 4x Arctic P12s running around 940 RPM (maybe the occasional and very slight ramp up from here) and an LL120 on the cooler running between 1,000 and 1,200 RPM. GPU is an RTX 3060 Ti.
How do your CPU temps fare in a CPU-only test? If your temps are high in a CPU test, it might be worth remounting the cooler and/or upgrading the thermal paste. If temps are alright in a CPU test but high in gaming, then it's probably the GPU's waste heat causing issues.
I re-mounted the CPU and ran a stress test for CPU only from a cold boot. Topped out at 69c. It's now settled down to around 42c idle temps after that test.
I have an Arctic P12 on the Shuriken and 2 x Lian Li Uni fans at the top set to exhaust. No other case fans. I'm assuming your 4 x Arctic P12s are two bottom intakes and 2 x top exhaust?
Don't think I'd have room for 2 x intakes at the bottom and it would probably hamper my GPUs fans intake.
