Permabanned
- 9 Aug 2008
Alright settle down it's only a commercial.
There was no acronym, it was all about stuff being properly bracketed, as I’ve already explained. That way, anyone can follow it.
I know, I saw you mention that there was no acronym, the point is that the order of operations still matters regardless of whether you learned an acronym at school, the answer is still -15. This isn't some brand new concept.
As he must recognise to some degree, as that's what tells him to do brackets first and not just do left-to-right regardless![]()
I think people just tend to forget the basics or don't pay attention to these things, why say 2x^2 is read as 2(x^2) and not (2x)^2 etc...
It's the order of operations that means we know to read 2x^2 as 2(x^2) and not (2x)^2, because they are what tells us indices have a higher precedent than multiplicationIf you know 2x^2 is read as 2(x^2) then you don't need to know the order of operations to solve it. (As long as you know brackets need to be solved first).
You'd only need to know the order to solve it if you didn't know that 2x^2 implied 2(x^2).
I'm starting to feel like there must be some Inception style 'wind up within a wind up' posts going on hereLOL wat?
How do you know it is to be read as 2(x^2) in the first place?![]()
LOL wat?
Because you've learnt that way.
You need to know various rules to understand maths. You don't specifically need to know the order of operations.
Interpreting how to put the brackets into it is essentially doing the same thing as defining the order, just with a slightly different process.
You know that 2x^2 is 2 (×^2) not (2×)^2 because the latter would be (2x) x (2x) which would be 4x^2.
Keep up in the back there.
Yes, you've learned.... which order to perform the operations!
Wat???No. If you learn how to correctly add the brackets then you don't need to know the order of operations.
Add brackets around anything which isn't addition or subtraction. It doesn't matter which order you add the brackets.
You get the same result both ways and then you don't need to know the order of operations to calculate the answer either
