Also, I'm running my 3080 with a gold 750psu and it appears to be running well, pairing it with a 65w cpu.
So I don't think you can get away with those power requirements on a 3090
Nvidia recommends a 750w for the 3090. I am running mine on a corsair SF750 with a 3900x and it is running great.
A 750W will be fine for a 3080. The 3090 FE draws 350w stock, with the power slider maxed it caps at 400w. So an extra 50w in consistent peak load. Obviously their are the power spikes to account for too. It might be cutting it close on a 750w when overclocked.I see, I did know that, so 750w should be ideal for the 3080. As I just checked and it says 750w for both 3080 and 3090, I thought the 3090 would get starved for power say your into overclocking etc.
I see, so those 1000w power supply recommendation YouTube videos are all overkill?A 750W will be fine for a 3080. The 3090 FE draws 350w stock, with the power slider maxed it caps at 400w. So an extra 50w in consistent peak load. Obviously their are the power spikes to account for too. It might be cutting it close on a 750w when overclocked.
The 3090 is barely cut down though, it’s 10496 vs 10752 shaders which is only just over 2% less... even if it scaled perfectly that’s basically nothing. As such I can’t see a 3090Ti unless process maturity is allowing higher clocks at lower voltages, but I could see a Titan which has both the full fat chip and the pro driver support.
3080Ti is interesting... the better option IMO would be to leave all memory busses enabled and go with 12Gb. The other option of keeping the narrower bus and going for 20Gb likely only really has the advantage of winning the PR war with AMD’s 16gb cards.
I have been convinced from the start that we’ll see a 3080Ti, only question to me is when. I personally put my bet on a 12gb 3080Ti falling somewhere not too far behind the 3090 in gaming perf, probably releasing by the summer but I wouldn’t be entirely surprised to see 20Gb just to win the spec war.
Of course actually buying one will be a whole other kettle of fish!
Watt meter tells me its pulling around 680-750w at the wall depending on watt i'm doing.
HAHA! Didn't even spot it, im half way eating my lunch and writing a report.Missed chance there...
What CPU's were they running?Some here (at least 2 members) had issues with 3090 on a 850w PSU as with Transient Peaks it hits 1000w, there issue went away once they fitted a 1000w PSU.
IMO yes, but the posts above state differently.I see, so those 1000w power supply recommendation YouTube videos are all overkill?
hence why I'm hedging my bets by trying to get hold of a 3080 now, then the ti when it does come out
so either your info is old (same source as Dave) or you know something we dont know. If it is released this year it will be after the summer.Yeah but then you also said we'd be waiting till September for the 3080ti, but current rumours are April
Did they have Seasonic Focus, or focus based PSU's? Just come accross a full article explaining that these PSU's specifically cannot handle the transient spikes of the RTX3080 or RTX3090Some here (at least 2 members) had issues with 3090 on a 850w PSU as with Transient Peaks it hits 1000w, there issue went away once they fitted a 1000w PSU.
For units, manufactured prior to January of 2018, the OCP is set too low. This leads to select GPUs, such as 2080 Tis, Vegas, 970s, and 1080 Tis shutting down randomly, due to triggering OCP and OPP, or because of high ripple at load.
SeaSonic produced a "fix", which is active on all units made after January of 2018. This really didn't fix it, however.
With the OCP being lifted higher, the units would produce absurd amounts of ripple at load. This can lead to instability and long-term component failure. Then, SeaSonic produced ANOTHER "fix", which was just a cable, with a capacitor and extra shielding, that reduced ripple. However, you would have to contact them to get one, and SeaSonic didn't include them in units.
