- 21 Jul 2005
- Officially least sunny location -Ronskistats
Timing will be good. You can creep into the river raids after completing then the druid expansion should be out to carry on with!
Run 1080P or 1440P to try and validate your results.Got the game downloaded but I've ended up annoying myself. So I can't beat 80 FPS in the benchmark at 3440x1440 at the ultra high present but this looks low compared to 120+ FPS scores for the 6900 XT at standard 1440p. This brings me back to a suspicion I have regarding whether or not my SAM is actually enabled. So, if I recall correctly, to enable SAM you have to have CSM disabled. I did this, however I use a sata pcie card for additional ports for my SSDs and it needs CSM enable to recognise them. So the steps I carried out were - enable SAM with CSM disabled - then back on to the bios and enabled CSM - checked the bios and it shows that SAM is still enabled. However, is the fact that I have now enabled CSM deactivating SAM even though is shows as enabled? Does anyone know the answer to this?
It wasn't giving me an option to pick 16:9 options but perhaps I need to change the aspect ratio first. I'll try that now...Run 1080P or 1440P to try and validate your results.
Yeah something's wrong there well below expected performance.Oh dear, 116 FPS at 1080p. No option for standard 1440p.
Going to try disabling CSM then bench and see what happens. Just had trouble after restarts with it disabled previously...
122 FPS at 1080p this time with CSM disabled. Going to try disabling rebar, reboot and go back in and enable...Yeah something's wrong there well below expected performance.
Edit: Just did a run of Firestrike extreme there to check the graphics score is line with previous results and it is. That reduces the spike in anxiety I just experienced there somewhat! Seems to be a game specific problem then, the plot thickens...
Edit: Ok disabled rebar, rebooted then enabled rebar. 124 FPS this time. Strange... Guess I can't play with you guys this time.![]()
Yep reinstall Windows in UEFI mode 20H2 build, CSM disabled in BIOS and Secure Boot enabled in BIOS, and get SAM enabled. Will add your scores later.I think my issue is that a few years back I had switched to MBR as I couldn't get into the Bios any other way due to the way my monitor posted during boot up. Doing some research it's seems my best option to clean up the issue and get SAM enabled is to a fresh install of Windows but I keep hearing He-man's mate Man-at-Arms saying "I have a bad feeling about this" when I think about doing it.
Anyway, enough grumbling and time to contribute properly to the thread with some scores. These are without SAM enabled:
5800X @ 5.025 Mhz
RX 6900XT 2702/2112
23.1.2
If anyone wants to "lend" me this so I can bench at 3440 x 1440 on a 3080 wiht a 9900k then let me know![]()
You miserable bunch forced my hand in to buying this (gladly after completing Odyssey!)
3080 @ 1920/10000
9900k @ Stock
It’s usually whatever GPU-Z says multiplied by 4. Mine says 1200, so I’m running at 4800Ha, well its 5,000mhz I guess but DDR - I just read it off the monitoring software![]()
Which 3080 do you have?I'm running +500 mem in Afterburner for 5,000mhz, over stock speed of 4,500.
