- 19 Oct 2002
- Shakespeare’s County
Speed read the video saw an MPH peak of 42mph i think.... Theres an Insight video doing 150mpg over 1500 tank. Thanks not a real world example.
you understand the difference between a hybrid stoping and starting where is has a benefit versus motorway where its just a engine pulling a battery along right? Aero is a big energy killer so dont assume a hybrid is massively more mpg just sat at a constant speed. There is the atkinson cycle benefit on the toyota engines though i admit.I get 400 miles in a city with stop start driving for £30-£35.
On a motorway at a constant speed of say 65mph you will easily get 500 miles for £35.
400 miles of £35 is far more realistic and is around 58mpg. That’s what you would expect on a run from a hybrid car.
It’s utterly miles away from your original post.
There is no pay a Prius gets 85mpg on a long motorway run and a diesel would be more efficient in that use case.
I get 400 miles for £35 driving around Glasgow. Stopped at lights, roundabouts constant acceleration and braking and driving at lowish speeds.
From the never ending battery ?
Its still not making power out of no where, that constant energy moving is not 100% efficient. The MG1 and MG2 are engineering masterpieces how they work in the Prius powertrain but they don't beat physics or Aerodynamics
Yes i have, I also did 700miles to and from Scotland and average was 70mpg in a mk1 Honda insight, that required effort and was a Honda engineering exercise with a very low drag car with covered rear wheels. You wont just rock up with 85mpg in a Prius /Ct200
Does the Prius have a lean burn mode? The Insight was able to get massive mpg by using the magic lean burn mode, and that was entirely based on the ICE and aerodynamics.
If the hybrid part of your Prius is charging while cruising on the motorway, your overall efficiency is going down. Petrol => Battery => Motor => Wheels is less efficient than Petrol => Wheels. The only way the hybrid part improves efficiency is where you are forced to slow down anyway and some of that momentum can be recovered.
