you understand the difference between a hybrid stoping and starting where is has a benefit versus motorway where its just a engine pulling a battery along right? Aero is a big energy killer so dont assume a hybrid is massively more mpg just sat at a constant speed. There is the atkinson cycle benefit on the toyota engines though i admit.
I get 400 miles for £35 driving around Glasgow. Stopped at lights, roundabouts constant acceleration and braking and driving at lowish speeds.
Going on the motorway to London it was 3 years back I got there on a single tank with fuel to spare iirc which lasted 2-3 days of local driving. So it did anywhere between 450-500 for £35.
Its still not making power out of no where, that constant energy moving is not 100% efficient. The MG1 and MG2 are engineering masterpieces how they work in the Prius powertrain but they don't beat physics or Aerodynamics
Yes i have, I also did 700miles to and from Scotland and average was 70mpg in a mk1 Honda insight, that required effort and was a Honda engineering exercise with a very low drag car with covered rear wheels. You wont just rock up with 85mpg in a Prius /Ct200
Does the Prius have a lean burn mode? The Insight was able to get massive mpg by using the magic lean burn mode, and that was entirely based on the ICE and aerodynamics.
If the hybrid part of your Prius is charging while cruising on the motorway, your overall efficiency is going down. Petrol => Battery => Motor => Wheels is less efficient than Petrol => Wheels. The only way the hybrid part improves efficiency is where you are forced to slow down anyway and some of that momentum can be recovered.
The way it works from what I can see on the computer is;
Roads aren't perfectly level. As you stick it on cruise control to stay at 50/60/70 depending on the stretch of road.
It will when going uphill or level switch between using just the engine or engine and motor or just the motor. When going downhill or sometimes even level it charges the battery. It also charges the battery when slowing down or braking.
