- 24 Sep 2013
- Exmouth, Devon
I've not tried Cyberpunk DLSS yet. I refuse to buy a game that's over-hyped and basically broken. Given it's general knackered status Cyberpunk's DLSS implementation is very likely equally borked. You should try some other games before you're so quick to judge on DLSS. Seriously - if it's done right it's wizardry.
If people are finding 4k and DLSS rubbish, they may not have turned OFF all the game options that are there to make potato resolutions to look better.
If you have a 4k TV/monitor and go in game and use ULTRA profile at 4k then you are doing it wrong. @ 4k you need to set EVERY game's gfx options under CUSTOM settings, turning off options (such as many post processing options) that were designed to make 1080p look better or blur the image (motion blur) for low FPS. You turn some graphics options OFF at 4k which also frees up GPU horsepower.
Too many look at 4k game benchmarks and think if they are getting the same then it's set up right. It isn't, that is a comparison and needs apples to apples settings. No 4k galer with a brain would turn on some post processing options and have AA at max. DLSS cant upscale a greasy image you've made with post processing, they are doing opposite things.
CyberPunk - well even one of the consoles dumped it as it's so broken. Hopefully it will be out of pre-alpha soon and be made into the game and be optimized for whatever RRP was. I really want to play it, but when it's better optimized I'll buy it - and it'll be £9.99 then. If that had been released in a decent state that would have bust record books with sales amidst a lockdown.
