My thinking too. He's been there forever, someone new has moved in and started changing things and he doesn't like it.Well done for being calm and looking at it from his perspective. The whole Englishman's house is his castle thing can turn nice people into ogres.
He got 54 years out of that shed, sounds like he's one of those old people that view change as a threat and resist it.
The run off of water is a problem, it looks like your bit all falls towards his he probably has a valid complaint.
However by filling the space up with a properly drained garage that drains into your aco channel at the front you are actually solving the issue for him.
@Gibbo his looks fine but there are many convoluted rules out there depending on planning authority and what’s already been built.
Generally it’s 2500mm high within 2000mm of a boundary.
I had the local planners out to make me take one course of bricks off a wall I built to keep it under 2000mm.
What’s the saying it’s easier to beg for forgiveness than ask for permission???
Guy just sounds like a grumpy old *******. Probably thinks he can get you to pay for all sorts too if you have a ferrari . Threatening lawyers isn't the best idea in the first place!
Wouldn't it class as a car port or extension if its tied onto your existing garage though or in close proximity to? Is it still within the 30m2 if so? That would be the only thing I'd double check
Seems fairly sound to me then if you've checked the local council website etc.Well it won’t be connected to that garage and will be it’s own independent building with its own guttering. It will be 15-20m squared. The current one is no doubt over 40m squared.
But from what I could tell from council website and various building planning sites you can use upto 50% of your garden space for out buildings and I’d be looking at under 20% by adding this additional garage.
I think if you put a black garage there, you'll probably never hear the end of his claims of it soaking up light. If you do get a black garage, paint the walls that face him white - it might be enough to appease him.
I get the impression you're tiptoeing around him while he just does what he likes with no repercussions. I understand why you're doing what you're doing, as you want to avoid an expensive garage being torn down. But I'd suggest to him that he moves his shed away from the fence to avoid future problems. After all, what's sauce for the goose is sauce for the gander.
@Gibbo Don't think you're doing anything wrong with that at all. It's not a permanent structure, I'm assuming its height will be around what's there already and it is replacing a previous non-permanent structure. Neighbour is being weird.
