- 30 Mar 2016
- East Lothian
True. The very same XFX Gold 850 PSU also ran my LC Vega 64 for 3 years without issue.No it doesn't, just like the LC Vega 64 didn't need 1000w.
Crashses as in power offs with over current protection, right?
A tragic waste for sure.Sadly it'll be hidden away in mine also
Not 100% sure as I do not have issuew as have a 3090 on a 1600w, but I could search the posts and reread.
Interestingly, I also have a 3090 on a Corsair 850w PSU.
It's fine on every game I've played, but Cyperpunk will crash out consistently after anywhere from 5-30 minutes play.
I can't imagine it's PSU related, though, as I'd have thought over-current would be cutting power not causing instability.
I have a 3090 on a Corsair 750w with a 3900x and it runs great. I doubt your psu is causing it to crash, likely just the game which is buggy.
yes if it didnt they wouldnt say that it did mhm
Thanks, that was my assumption to be fair.
You think it needs the same size PSU whether it's got a 10900k that'll pull 300-330w or a 5800x that'll pull 120-140w?
The 900w assumes you're gonna use your 6900xt which is a top of the line gpu with a top of the line cpu and even overclock it cause that's normally what people who spend 2k on a gpu would do. If you're one of those who pair entry level parts with top of the range parts then sure you can figure out your own psu requirement, you can even underclock your gpu to lower your pay some more
It is buggy for sure. Overrated? Compared to the expectations that were set, then yes it was overrated before it was released. Now? If anything it's underrated as there is so much hate flying around and folk dismissing it without giving it a chance. It's still a damn fine game and if you were looking forward to it previously, then you're only denying yourself a great gaming experience in my opinion.I am looking through here: Search Results for Query: Transient Spikes | Overclockers UK Forums
I know Cyberpunk is one very buggy overrated game and I will no doubt never play it but is it not very stressful game (like Crysis was) so could cause crashes others do not?
Mildly oc 10700k that pulls about 180w according to the board software.
3090fe undervolted to 900/1950, pulls about 330w.
3ssd, 2hd, 4 ram, aio and lots of fans and fairy lights.
Most I've seen for the full system is 550w while gaming, 500 is more typical.
Boringly stable on an Asus Thor 850w.
And there is me with 3090 at 500w alone
I've seen over 800w from the wall with the full system going, using with those cheap wattage measurement plugs (but they don't capture transients as they aren't nearly sensitive enough not do they have the ability to output that data). Thisnis with a 5950x though, if I switched to something like the intel 10980xe there's no telling what I could do, probably over 1000w from the wall
From the web, the detailed information is a bit down in blue Will Power Spikes be the downfall of 6800/6900 Ser... - AMD Community
Perhaps one way to cut down on crashes is to use Radeon Chill to set a lower frame rate range in some games and so reduce power usage.
 get the LN2 on standby I say.
 get the LN2 on standby I say.Absolutely nothing to do with the OP dilemma. Simply expressing concern and pointing out to a fellow gamer that if he is deciding to not play the game based on the general mob consensus, then he could be denying himself a great gaming experience. I have over 100 hours in it and was still disappointed when it was over as I wanted more. I'm personally glad I decided to give it a shot and just wish the same for others.WTF has that to do with his (the Op's) dilemma?
I have never gave Minecraft a chance but I sure as hell will not play it ever!
You do know like movie trailers you can watch gameplay video and get an idea of if it is your thing or not.
good psu.Well I got a chance to game on the 6900xt properly today.
I spent 1-2 hours on Cyberpunk without a single crash.
That's on the 850w Thor PSU and Power limit maxed out - it seemed to hover around 330w according to Radeon overlay.
It'd be interesting to try the 3090 on this PSU and see if the crashes in CP go away.
