I've had one particular panel suffering from condensation within the two panes, after my dad powerwashed it from outside. Other windows also washeed were fine though.
Water has collected inside over time, and now 3-4mm high.
I've already had a glazer come round and give me a quote to replace the unit, stating that it cannot be repaired as the seals are probably worn. A look online suggests the same solution. Windows are 10 years old.
Just wanted to double check no one has come across a repair option, which would save on a complete replacement?
