Hopefully you don't suffer from the cutouts that the 9X are known to have unless it's been fixed/patched out.
That's been sorted with the latest firmware.
Just given them a go and they sound fantastic miles better than the MS headset but to be expected as they are twice the price. They are not quite as good as my Bose which I got on the MM for a bit less but there is no delay connected direct to Xbox so much better in that respect.
They do the job perfect which I was hoping the MS set would do. Very happy with them.
Great stuff, glad you're happy with them.
Do you not fancy a keyboard and mouse? I'm seriously considering for FPS games but will hold out a bit to see if I get used to it or not.
Is this the Arctis 9X, is the Mic removable? I really want to go wireless with a headset and was waiting for the MS headset but it seems the real user feedback isn't great
The mic slides inside the headset, out of the way completely. They were very flaky at launch but the latest firmware has fixed the issues I initially had. I can't do FPS with a joypad, hate it with a passion. The Razor Turret also works on the xbox wireless protocol but has a tiny dongle for the mouse.
