- 18 Feb 2007
- London
For most games that support FPS boost and/or auto HDR, the feature is on by default. However, for some games, you’ll need to enable it manually. To do so, go into the Manage game section of any title, and then select Compatibility options.
To enable FPS boost, simply check the box. If you prefer to disable FPS boost and play the game in its original form, uncheck the box.
Thats from xbox support, not checked myself.
Thanks will take a look later, don't think I have any installed though that make use of it.
i missed it first time round and has the simular soundtrack to the ps1 doom games.
I tried FO4 earlier but it wasn't enabled so it'll probably be sometime tonight! According to that article, with it enabled on Fallout 4, the resolution drops to support it properly which is a shame but nevermind, it'll be nice to have 60fps in Fallout 4!
