The settling period on full fibre is BS. It sounds to me that you’re on the wrong profile.
It sounded BS but she was just reading from a script and at the end the only option she had left was 'please give it 10 days'.
You got anything else running.
I was getting about 148-151 from my 150 service, the very second all the lights went green on the ONT.
I had to show real restraint in getting the 150 rather than the 900. Being honest it just wasn't required, even with 4k streaming it's plenty fast enough to then download a game or whatever.A few devices connected to wifi but nothing was actually being used at the time.
I'll keep an eye on it over the next few days. She couldn't even check what speed I was receiving, apparently as it's 'only been installed yesterday', it wasn't even showing anything on her end to check. The only thing she had in her notes were '450 dl minimum expected speed'. Even that was news to me tbh, I'll probably switch to 300 if that's the speed I'm getting and save abit on the monthlys.
Will report back in 9 days time.
If you want to do a proper test plug straight into the ONT and do a speed test.
EE engineer came out today, waste of a callout tbh. I had my laptop already set and wired up, speedtest showed ~480 dl and ~20 ul. I told him it never goes above 20 ul and the dl varies from about 80-500 wired, and 30-350 wireless, uploads max out at 20. He said 'nothing I can do here, this looks capped from BTs side somewhere, Openreach need to look into this. No amount of tinkering here will fix that.' Oh, so pretty much exactly what I said to EE on the phone? He said yes, sorry I can't help you further, I'll escalate this for you and they should be out here soon. He wasn't here for more than 5 mins.
I rang EE immediately and they're now getting a BT engineer out tomorrow. She was keen to know exactly what troubleshooting todays engineer did, and I said nothing, he could see its capped. She said I'll have to report him, they aren't allowed to say that!?! Even though I think he's right she was insistent their may be a fault on the line somewhere and he should have used all his equipment and gone through various steps, all of which he didnt.
They aren't using fibre, they're using the exact same FTTC line you already use and you probably won't see any changes to speed.I'm currently with Sky (DOWNLOAD Mbps 43.86 UPLOAD Mbps 18.78) and the EE checker suggests I will get Fibre Plus "We estimate your line will be able to support download speeds between 55 Mb/s and 73 Mb/s and upload speeds of between 17 Mb/s and 18 Mb/s."
If they are installing fibre to my house why does the upload speed not see any improvements?
I misread the OPWhere have you been told that fibre is being installed to your house?
If he can see the ONT is connected at 1000mbps then there is very little he can do. It does look like a profile issue.
EE giving a good demonstration as to why I've gone with someone a bit more expensive. Everything is all well and good provided it works, it's situations like this where better CS comes into play.
Openreach engineer came by today and was baffled as to why he was even sent out. He said 'our job is just to install the line and make sure it's working okay, which it is.' I explained the only issue was the speed and he said that's EE's problem to sort out. Spoke to EE on the phone after he left and they said it's Openreach who are essentially providing the service, they are the 'middle man'. The notes they received from the engineers visit just state line is active and working, they've sent it back to Openreach as unresolved and so another, yes another engineer is coming tomorrow. Wow.
