If dots are not appearing on screenshots then almost sure that is monitor/cable issue not gpu?
Once again
Why do you keep trying non native resolutions?
Because somebody said that i have faulty GPU.![]()
Just need explanation thats all. If rma monitor or gpu. But like i said. When i made perform scaling from DISPLAY to GPU dots dissapear on 1080P 165hz.
Also when i wanna make screenshot dots are not appearing on screen. Thats all. ITs monitor or gpu? Also nothing to worry about? Thats all Hedge.
so no rma?Dude you need to just use your monitor at its native resolution. You own an rtx3090 for gods sake.
Why are you insisting on playing at 1080p.
Buy a new 1080p monitor if you must.
so no rma?
I asked to be sure if thats not gpu issue.Gpu its fine?![]()
