Call me when AMD's products are so good that the OEMs buy only them. For now, it is not happening.
Yes, Ryzen 9 5950X is twice as fast as the Core i9-10900K but also doesn't cost the same but considerably more.
What are on about? Why would you expect OEM's to shift to all AMD products? The point would be wanting parity with both companies. Not one much ahead of the other. And we all know the reason for the huge number of OEM Intel compared to AMD came from anti-competitive bribing in the first place forcing AMD in a situation they have been recovering from which ironically led them to where they are now with a great Zen product line-up.
In terms of prices, the 10900K OEM is selling around the £460 mark, the AMD 5950x at retail is £750. So you are getting 100% performance for 63% price increase. However you also have the options for the 5900x with it's 12 cores which still gives a hefty performance increase in performance whilst only being £80 more. Or if you look around some places have them on backorder for £525 at moment. I personally think for the price the 5900x is the clear winner out those two. And ironically even with 2 less cores the 5800x competes in the gaming performance just fine at £420 price point so you can have the same performance for £40 less than Intel currently.
Nothing Intel is releasing is looking to upset this balance either. You also brought up before about more cores from Intel, yeah and how much monies do you think the 16c24t Alder Lake is going to cost? It still only provides the same core count as AMD do currently but with less threads due to it's design setup on BIG-small chiplets, it would need to maintain it's high clock frequency (which they have come out suggesting already it wont) and also gain at least 20% IPC to be competitive still with AMD's next major CPU release if those leaks are correct. That is a tall order and looks like Alder Lake might well struggle with AMD's future release still.
