It makes you realise just how good IVS is.
It was excellent in order to avoid false alarms but (with my setup) quite random in performing its primary function (detecting an intrusion).
@Nitron I had problems with mine too. Do you have 'motion detection' disabled in the 'video detection' tab. After disabling that, the IVS seemed to work ok and walking around outside (entering / exiting the boxes I setup) triggered the alarm.
My only issues now is my NVR (using a synology NAS) does not fully support the camera and for some reason it will not trigger to record as it should i.e it wont record when I walk outside in the area, even though the camera's LEDs flash blue and red. For now I've set the NAS software to detect motion (instead of the camera) so I get a lot of false recordings but TBH I don't mind as at least it will pick up any intruders now.
Are you aware of the two-way speech function? From the phone app you can speak to people over the camera.
Any feedback on this model compared to the colorvu models? Particular keen on the adjustable lens as I'm not sure what is best for our requirements.
Hikvision 2CD2645FWD-IZS
Thanks
Thanks, that camera is available for around the same price as the ColorVu. With the ColorVu I'll have to decide up front what the lens size. The common 2.8mm does not seem appropriate in most cases, as unless you are really close up you won't recognise things?
Off course not. On a tight budget (for a charity) so looking on Ebay. If you check out that model number on Ebay you'll see it available for £140 (or best offer) for a new model. Obviously lower price due to lack of official warranty.
Your £117+vat seems like a good price, even compared to Ebay sellers.
Hikvision are not great for door entry solutions.
The default option is DS-KD8003-IME1 at £100+VAT (with our without the surface mount kit at £22+VAT) and the DS-KH6320-WTE1 display transceiver at £100+VAT. Both are powered by PoE if you have that available and they 'just work' together out of the box. They also play nicely automatically with Hikvision NVRs and phone apps.
Can anyone recommend a tidy Wifi IP camera that uses ONVIF or is qnap nas compatable?
