- 11 Sep 2013
Probably just a 'latch' or a 'catch', possibly a detent.Out of interest, if it did only continue to apply the brakes after a braking action, what would you call the function?
As you describe it in the quote above, it's essentially no different to a retractable Biro™ or a door latch. You wouldn't call that an automatic mechanism, would you?
Could just call it the brake-hold or brake-detent.'manual hold' doesn't really sound right for a system that continues to apply the brakes after you release the brake pedal![]()
TBH, I think in this instance calling it "automatic" is more for marketing purposes than being technically correct... like how people 'literally' misuse the term "literally".
Automatic things are generally perceived to do something, like an auto-pilot. They don't automatically sit there doing nothing.
Saying that, there are plenty of other things that continue to hold something in place after you let go, though none of which are considered (or called) automatic. Tools like squeeze-clamps, for example.
. They radiate heat then convect it around the room. Also vacuums do create a vacuum (that's how they work).
