They are a bit wankelI really need to scratch that rotary itch one day.
Thanks! Been practicing.. trying to get a bit better with the camera. Nothing is ever as easy as it looks lol.Lovely shots there @grudas
Ah yes, if anyone needs free upgrades.....
What are they doing?
Maybe they didnt know he owns a 5 car collection mate
Renault price is £265.20 + VAT + fitting
but I managed to find an OEN new for way less
Popped down for some takeaway..
S2000 needed to go for a run after sitting for weeks.
https://i.~ibb.co~/THFyPPN/DSC1483.jpg
https://i.~ibb.co~/4SfLnby/DSC1508.jpg
https://i.~ibb.co~/mG1KwX0/DSC1401.jpg
Yep on 2.0 Turbo engines it is (most mk3 Megane have the 1.2-1.6 engines there are very few with 2.0 spec like mine). Exact same exhaust system & engine type as the RS MK3 (RS has slightly larger intercooler & turbo boost is 0.2 bar higher). The other exhaust option for 2.0 is invisible you cannot even see it the tailpipe ends before the bumper & vents down slightly. The 2014 mk4 facelift removed the 2.0 engine option. Then in 2017 they came with yet another system which was changed again 2017-present. You can buy several different aftermarket skirts which cover & integrate the exhaust into the rear differently but most just leave it as is!Is that central exhaust stock?![]()
Thank you!Lovely s2k. Awesome colour.
It sits beneath the rear skirt its just an exhaust tip to vent the gasses away. If you see the model with no exhaust tip as per this pic (the only other option for 2.0 engines).The exhaust looks very odd to me, the bumper hasn't been styled to accommodate it at all!![]()
