Merely have to dig a trench a couple hundred metres wide and 20-30m deep and do that for 120 miles if you want another canal.
Absolutely spot on, days/weeks and indeed months sometimes, at sea, bored out of your mind to put it mildly.I imagine living on a Cargo freighter to be exactly like living on an oil rig. IE boring AF, mind numbing, monotonous noise.
Depending on your crew you could be eating curry with your hands for every meal
Someone said a floating Butlins... lol deffo 1990s furniture ftw.
Honestly not a romantic experience at all. Probably -50x slower and 5x more expensive than a flight too..
A mate of mine did a two year traveling stint and got passage on a few container ships , he described it as fascinating from his perspective but for the regular crew for whom it was their day in day out, he wondered about quite a few of them mentally, I guess huge lengths of monotony and boredom does little good for the mind.
That said he was planning a similar jaunt ore covid so it couldn’t have been all bad ,for him at least.
The American government looked at making on in Israel using nuclear bombs for the excavation! It would be easier if the canal wasn’t owned and run by a third world country.At a cost of US$56B, apparently. I wonder how much it would cost to make a second Suez canal and if it's possible to do so.
Not 120 miles.Merely have to dig a trench a couple hundred metres wide and 20-30m deep and do that for 120 miles if you want another canal.
Surely there are anchor winches. Or do the tugs do the anchor lifts?I believe the problem with both winching and towing is that the pulling power required to move such a huge ship would just pull the ship apart. There are no anchor points on the ship strong enough to avoid being simply ripped off the ship.
absolute chonk of a boat, only 3 years launched and already failing to the point of crashing. Seaworthy ?
It's too big to carry such a vast amount safely, or at least kepp control of. How likely is it that it'll be allowed via the canal again?
Crikey the number of tugs following it, I bet that driver is a bit shakey at the wheelLooks like its been freed now. Vesselfinder shows it facing north and moving of it own accord
It's among the bigger ones, but about the going rate for container ships.Is it bigger than normal cargo ships?
Yes, it's currently the biggest I believe in its load capacity. Problem is when fully loaded it can't course correct when side wind hits it effectively.Is it bigger than normal cargo ships?
