Caporegime
- 9 Nov 2009
- Planet Earth
I just got hold of a Core i5 10400 and a B460 mini-ITX motherboard for under £170 for a secondary system. Hence there are deals to be had on CFL too,and CFL will also work in the B560 motherboards too.Brill, sounds good. I remember the 10400 being a bit lacklustre in reviews, and that was down to the ram being limited to 2666 on the boards you'd expect to run it on.
I have a 7600k in a second machine paired with a Z270m board. I could probably swap to the 11400 and the cheapest B560 for not much outlay.
Then again, I have a B550 board going unused that I needed to buy to get the 5600X. So it might be less hassle just to chuck a 3600 into that.
Well, or just leave it. It's only running an 480 8gb.
