I purchased a Bykski V2 3090fe block and couldn't be more pleased with it, comes with back plate at about £100 all in including post with RGB and the fit and quality was superb. my only critique would be the instructions were poor but having used Blyski for a Radeon 7 card before i was impressed with the performance.
2 x 480 rads with 8 fans push pull on each with 2 x big res, one rad for CPU one for GPU separate res on each keeps all nice and cool.
https://i.~ibb.co~/T8V40NM/junction-2.jpg
https://i.~ibb.co~/qD4KnYp/pc2.jpg
Btw did you replace pads on the cooler? Most Reddit seems to think the vram junction can reach 90 degrees on Bykski, I am thinking of getting it as a filler until EK release their hybrids
idling at 13c? jesus dude, how do you not have pneumonia in your lungs, your house is not safe for human habitation
I had the zotac one and it was 50c on ideal and 73c under load but with ek water block it was 30c and under and with load 48c with water temp at 38c but ek messed up on the water block as it buzzed
I got no buzzing, and the bykski block seems to work very well. and very good value to, under £100 including back plate and postage. I cant complement the finish enough, very well machined and fits like a glove.
Thanks, I’ve ordered one as it seems to be one of the few out there that is still available.
Quick question, how long did it take to arrive from China? Also what are the thickness of thermal pads?
That seem very hot epecially the CPU
Whats the room temp
Are these temps ok?
Hardware to cool: 5950x cpu using PBO and rtx3090 Strix gpu @ stock
case: lian li o11 xl
Cooling: 3 x ek pe (360x40mm) radiators with 3 fans on each
Blocks: ek quantum gpu block, ek velocity cpu block
CPU temp under load: 85c
GPU temp under load: 61c
correct me if I am wrong, water flows from the reservoir to the GPU block, then to Mosfet block, then CPU block, then to side rad, then bottom rad, then top rad and back to reservoir
The cool water is getting warmed up by the gpu, then the vrm and then by the time it reaches your CPU it's no longer very cool.yes that is correct and for fan direction: bottom in take, side in take, rear exhaust, top exhaust
edit: oh and the pump is at 50% PWM (2400rpm)
