Cheers mate , its a work in progress
you should get some impressive results with an external rad setup , post up how you get on with that will be interesting ...
If/when i change the pc case one day may go for an open air case of some sort as really does make a nice difference not having it all stuffed in a case
The Byski flow/temp meter seems pretty accurate from what i can tell and is nice having a flow meter to read , as for mounting it i chose the outlet on the bottom rad so it s clearly visible... for the most accurate flow reading would imagine you would want it on the outlet of the pump but would mean having it stuff at the back in my case so just stuck it on the front
as standard its setup up to have flow in from right and out from left but very easy to change this by undoing the G1/4 connection and swapping the flow sensor around so its flow in left out right which is what i had to do.
If using soft tubing they yeah would look at mounting the flow sensor somewhere so its is secure
The cable is a Molex on one end but is snapped the other end where its goes into the sensor, looks like the previous owner tried to pull the plug out for whatever reason and instead ripped out the wires from the plug which is absolutely tiny
Fingers crossed it doesn't take 4 weeks + for it to arrive like the thermal pads from Germany
