Caporegime
- 18 Oct 2002
so there must be some throttling or the like going on for me on air.
Think that's a PL issue iirc, but 22k gfx score is phenomenal!!
Yes, that second test draws by far the highest power in a particular place. It trumps normal Timespy and all the Firestrikes for power draw. If you can pass 20+ runs of that, you should be stable under heavy load in all games.@LtMatt has suggested to me in the past that looping 20 runs of GPU Test 2 is usually solid for him for games.
I really need to pickup 3DMark when it's next on sale.
Nightmare - does rolling back to a previous driver solve it?
Use Cd Keys its £2.89
No, but I have seen a few reports of driver time outs on that driver, try rolling back for now.Anyone had Bad_Pool_caller after updating the drivers? Didn't have an issue until the last update.
Gutted I have had to rma my sapphire 6700xt. Coil Whine was louder than the fans.
! Try loading these profiles into GPU Tuning and see how you get on. The 2340/2400Mhz ones should lower your temps and fan noise. You may be able to adjust fan speed and voltage further but this gives you a starting point.Yo guys, just signed up after lurking here for a while, super informative thread this, thanks for all the info!
Had my Asrock 6900XT Phantom D for a while now, since my trusty old 1080ti blew a cap about two months ago. (worst timing ever)
Anyway, I'm super happy with the performance but I'm trying to get it a bit more silent under load, if I want to "lock" it at say 2300mhz, what's the best way to do that? Put the minimum and maximum clock sliders in Wattman on 2300mhz? I'm playing Outriders atm on a 3840*1600p Alienware monitor and man does it get super loud at times... I would also want to avoid capping the game framerate too much with that Radeon Chill stuff.
6900 XT GPU Tuning Profiles - OneDrive (live.com)
Try now.Hey LtMatt, thanks for the reply! Looks like that OneDrive link is "empty", no files there.
Try now.
Been testing out a maximum stable overclock on the Merc and I'm able to run 2775Mhz core clock (2725Mhz+ in game) and 2124Mhz on the memory fully stable.
Fan speed of 50% and that can keep temps under control whilst not being noisy.
Found a 3090 FE user running the exact same settings, but with an Intel CPU and the GPU at stock (i believe) and the 6900 XT appears to be 25-30% faster which seems pretty good to me considering this is a Nvidia sponsored title.
9:50 - 2160p Ultra - DLSS OFF
