- 31 Oct 2005
- Wirral
Coaching is definitely something I could do with. I don't have a ton of experience and I'm crap at simple things like manualing
Who'd you do it with mate?Yeah, I can imagine. My only experience is of it being around recently(ish) and people moaning about it being no good. Which it isn't of course, it's probably one of the biggest upgrades anyone can do.
Had a coaching day yesterday with a DH/Enduro Pro. So much learnt in such a small space of time! I took about 30% off a trail I'd done a few times before this, without trying at the end of the day. Anyone on the fence about spending the money, do it. Wish I'd done it sooner, and I'll be having a few more in the near future.
I made my own tubeless tyre inflator with a 2lt pop bottle and an old bit of hose and spare valve. Pump the bottle up to 80psi and it seats tyres instantly.
Regards bodging tubeless technically anything other than Mavic UST is a bodge.
Switched to tubeless yesterday after some extra bits arrived which I'd need to keep in the shed anyway for maintenance. The back tyre seated and sealed perfectly and I was able to lock the bead to rim with just the normal floor pump. It's holding air and the muc-off sealant seems to be doing its job after the sealant dance was done.
The fornt tyre however just can't get it to seal the same with the floor pump, feels like it needs a higher gush of air to force the beads to the rim edge. I'm going to redo it, clean it all up and re-tape the rim too just to be sure but after some Googling I have seen examples from people who received a faulty tyre too so it could well be that if all else fails which is somewhat annoying.
I am pumping with the valve core removed btw to allow more air in just for the initial seating of the beads.
I did manage to put the back tyre on the wrong way round but was able to correct it without spilling any sealant which I was impressed with
I have ordered a Schwalbe Tububoost to help with the front as it does seem like a useful thing to have in situations like this, so if this doesn't work then it probably confirms a faulty tyre and off to contact Wiggle I go. I might double tape the rim as well with a layer of electrical tape for the extra cushion as have seen this is one method if initial seal isn't playing ball with just 1 run of rim-tape. Also have seen the soapy water pre-sealant fit and pump too so will try a bunch of stuff.
Bit like this,Any pics of that DIY build?
With the use and budget in mind I'd definitely recommend trail HT, you wont find a FS at that price range worth slinging a leg over, unless you look used, but even then its a bit short to be finding anything modern. Its a bit of an awkward price point, as it sits in a bit of a gap between low spec(£500-£700) to mid range (£1000-£1500). But I think at that sort of budget I'd be looking to see if you could find something like a Marin San Quentin 1.If mostly trail riding at that budget I'd suggest a hardtail myself.
