Hey guys, sorry to hijack the thread but can you not just undervolt the cpu to lower temps? I just got a 5800x myself coming from a 2700x, that was a hot chip but i just set volts to 1.35 and it boosted fine and never went above 60c. Is the 5800 different?
You can, you can even set it to run at a fixed frequency at a fixed voltage, but in doing that you lose its ability to always get the most out of its self for any given workload, that's where the Curve Optimiser comes in, you can customise your particular CPU to behave in a way that is particular to it, because no 5800X's are the same, some are better than others and the perimeters i'm talking about are set identical for each chip based on a worst case scenario because they can't know the characteristics of every single piece of silicon that leaves their factory.
Its why all CPU's and GPU's have some form of "overclocking headroom" because 99% of them are not Worst case, its that 1% that the perimeters are set for.
Its new technology, new improved ways of doing things, as enthusiasts we need to keep up and update our knowledge, there hasn't been any competition in the CPU space in over a decade, now there is and with it comes new ideas.
Thanks I am all new to AMD and still learning as I been using Intel i7 2700K for almost 12 years. Big change from Intel to AMD. Now a final question: Am I better off leave it all on auto and don't worry about up to 1.5vcore or am I better off with my fixed ratios x 40.25 and set vcore @1.250v? Cos the benchmark only slightly little difference
Leave it auto, put it back to auto and run Cinebench all core, keep your eye on the volts, you should find its not running at 1.5v during the benchmark run, but somewhere between 1.3v and 1.4v, if you run cinebench single threaded then it will run at about 1.5v. Completely normal.
If it isn't behaving like that let me know and we will try and figure out what's going on.
