In PCVR stuff I find it hard to tell any difference between 72/80/90. Maybe I'm broken.
I didn’t notice any real difference either. When I played PC2 racing it looked the same.
The graphics were set on i think 1.6x
i didnt get VD long ago, hope this update works
tempted to get a refund on VD
as i cant use it to play games
Play Eleven table tennis, and watch the ball. The difference in smoothness between 72hz and 90hz is very noticable. The ball moves so fast it looks stuttery on lower refresh rates.
The VD developer is going to be out of a job soon![]()
You still having problems? Have you tried getting a dedicated WiFi AP? I'm only on 866mhz WiFi and gameplay seems fine for me. You can get a TPLINK 802.11ac ap for less than £50, double that for WiFi 6 unfortunately.
Hopefully he'll be good for a while yet. It took link a good while to catch up with VD in terms of image quality. I still find VD to better in terms of compatibility as well. I don't imagine their wireless solution will be ready for prime time yet.
any recommendations ?
The routers do 802.11Ac provided your lan card supports 5hzi dont need a router (its the 802.11 AC or what every its called)
but thank you anyway
thats for wireless
the Ethernet to router though is 2.5 ? do i need to buy a 5Gbs Lan controller ?
