Had to order the following:-Where did you get the switches from?
- A pair of Lutron Aurora Hue dimmers (those are the Hue compatible rotators - These are designed to clamp onto actual existing light switches)
- A pair of Lutron Aurora wallplate brackers - As I'm not fitting those dimmers onto existing light switches, I'm using a pair of purpose made brackets for the dimmers to fit onto.
- A Lutron faceplate to clip over the two wallplates.
See if these help explain it:-
- https://www.amazon.com/Lutron-Aurora-Dimmer-Philips-Z3-1BRL-WH-L0/dp/B07RJ14FBS
- https://www.amazon.com/Lutron-Wallplate-Bracket-Decorator-L-AWALL1-WH/dp/B08JD3NXP8
- https://www.amazon.com/Lutron-Claro-Decorator-Wallplate-CW-2-WH/dp/B000MAUTFY
I had to source the former two direct from the US. The wallplate I managed to source in the UK thankfully cheaper.
This cost just over £100 to put togethor. But as it's for our louge/dining room, I figure it's worth it. And it's somewhat more natural in usage than Hue dimmers.
Note: It's larger than a convention dimmer. About 12cm square.
