ClockTuner 2.0 for Ryzen... do YOU have a Golden Sample? Post your results here. :)
Deleted member 66701
D
Thanks, thought that's what it meant having seen a few mentions of it. From what i've read, 5950x has a very good CCD and an average CCD (this may be wrong of course) - possible I've got a pretty good 5800x then if the disabled CCD was the average one. Still, it's like having an extra pie that you're not allowed to eat
It's very likely that disabled CCD could be faulty though.
29 May 2005
This programme has a slot of bugs. It’s not the most polished programme for sure. It’s also obsolete unless you want to severely under volt the CPU such that you run it at 1.1V.
not sure who wants to run a CPU like that, maybe in an ITX case where there is virtually no airflow and the cooler is really poor or there is a big GPU pumping out a lot of heat.
22 Jul 2010
This software just brought me misery lmao.
Confirming that my 3600X is BRONZE and clocks lower than some 3600s (non X).
Basically the X branded CPUs are obviously a rip off. And it is just annoying to find out your chip is piece of a junk lol.
22 Mar 2009
I don't believe this software to check AMD cpu for Bronze, Silver or Gold. Loads of crappy software build by programmer person.
Don't let this software put you off! AMD will never sold u junk CPU anyway.
3 Feb 2008
uk
I only ran it once out of curiosity. I've seen others report running it multiple times and getting different results each time (not surprised tbh). You could very well have a great sample so your misery may be premature!
24 Mar 2006
UK
DIAGNOSTIC RESULTS
AMD Ryzen 7 5800X 8-Core Processor
CPU VID: 1098
CPU TEL: 1080
Max temperature: 67.9°
Energy efficient: 4.05
Your CPU is SILVER SAMPLE
Recomended values for overclocking (P1 profile):
Reference voltage: 1250 mV
Reference frequency: 4575 MHz
Recomended values for overclocking (P2 profile):
Reference voltage: 1325 mV
Reference frequency: 4675 MHz
Recomended values for undervolting:
Reference voltage: 1125 mV
Reference frequency: 4325 MHz
Cooler is an Arctic Freezer 13 that I've had for several CPUs (back to my Athlon X4). Is it worth upgrading the cooler?
Caporegime
OP
8 Sep 2005
Utopia
I wouldn't bother use this crap software as it not official by AMD. You are at your own risk to brick AMD CPU.
If it didn't have 5000+ posts I would think this was a new troll account. Holy moly, this is some 'special' kind of posting. :D
Rab
Rab
21 Oct 2005
Scotland
here mine on 3600
DIAGNOSTIC RESULTS
AMD Ryzen 5 3600 6-Core Processor
CPU VID: 1048
CPU TEL: 1049
Max temperature: 64.9°
Energy efficient: 3.86
Your CPU is GOLDEN SAMPLE
Reference frequency: 4375 MHz
Reference voltage: 1350 mV
Reference frequency: 4525 MHz
Reference voltage: 1175 mV
Reference frequency: 4225 MHz
11 Apr 2008
Sheffield
doesn't work with non-x CPU's as it assumes the 'stock' values too low, I got 3900 which happily runs under 100% load 24/7 when rendering at 1.26v @4.25ghz all core locked under max load, yet, this tells me my CPU can only do 4050mhz at 1.35v or 3900mhz at 1.25.
The 'tune' feature sets at 4.35ghz few core boost at 1.3v, yet I can quite happily run 4.35ghz all core if needed with that volt and boost up to 4.4+ single/few core on high volt.
Not sure what I was expecting but it's not better than ryzen master or auto-oc on motherboard (at least auto OC pushed my CPU to 4.35-4.4 instead of deciding 4050 is all it can do, when it sits at 40c under load)
6 Feb 2019
This software is "too dumb" - it makes far too many assumptions and can be duped of your settings don't exactly match what it wants you to have. I'm sure the results are ok in a perfect environment but too many CPUs are not operating inside it's assumptions, the software needs to be much smarter and stop spitting out absolutely rubbish data
6 Oct 2012
Well it's not a made up score/rating, just based on data available to them. The sample rating/scores are based on the maximum performance percentage which you can see via Windows Event Viewer (ID 55), so bronze, silver, gold or platinum will be where your aggregated/average(whichever the software uses) values sit amongst their data for the same CPU.
I still wouldn't use CTR yet, too many bugs and early in its development. It's not too difficult to have a play around with Curve Optmiser yourself, just takes time to stabilise.
8 Jan 2003
Scotland
AMD Ryzen 5 5600X 6-Core Processor
CPU VID: 1079
CPU TEL: 1063
Max temperature: 60.1°
Energy efficient: 4.12
Reference voltage: 1150 mV
Reference frequency: 4425 MHz
Reference voltage: 1300 mV
Reference voltage: 1025 mV
Reference frequency: 4175 MHz
Cooler is an ID-Cooling IS-60 with 2 x Arctic P12 120mm fans.
5 Apr 2004
Just got the chip today. Seems averagely gold from what others have posted.
DIAGNOSTIC RESULTS
CPU VID: 1056
CPU TEL: 1033
Max temperature: 55.3°
Energy efficient: 4.24
Reference frequency: 4775 MHz
Noctua nh-d15 chromax
Caporegime
OP
8 Sep 2005
Utopia
I now have my voltage offset to -15 (everything else on default) and its pulling in a sustained 4625mhz in Cinebench R23, which is better than my previous all-core manual OC at 1.26v. Think I've more or less hit my peak for PBO with my current cooling.
Stu
Stu
19 Oct 2002
Wirral
DIAGNOSTIC RESULTS
AMD Ryzen 9 5900X 12-Core Processor
CPU VID: 1200
CPU TEL: 0
Max temperature: 60°
Energy efficient: Infinity
Your CPU is PLATINUM SAMPLE
Recomended CCX delta: 0
Theoretical maximum CCX delta: 25
Reference voltage: 1275 mV
Reference voltage: 1000 mV
Reference frequency: 3875 MHz
I'm not sure I did this right... it ran a single C20 run and that was it... is that right?
APW
APW
15 Apr 2021
DIAGNOSTIC RESULTS
CPU VID: 1200
CPU TEL: 0
so, your platinum sample 5900x runs smaller clocks than my bronze sample 3900, yeh.... sure... good reliable test :D
27 Jan 2003
Chesterfield, UK
Just got my 5900X a couple of days ago and ran this. Said it was platinum but I can run negative 30 on all cores with the curve optimiser and a boost override, only tried 50 to get to 5 GHz but it worked. Never pushed it further. It’s obviously a good chip which kinda ties up to this.
