- 19 May 2005
Halifax bank lets you scan cheques using the app
The router port will auto negotiate speed, if the cable isn’t to spec, damaged, or the device on the other end has issues or is set to 100Mbit, it can drop to 100Mbit which would give around 10MB/s.
YepWhoa thats insane tech. Does barclays do it?
just used it now and it did scan it. cant believe how simple its become.
Is that from a wired device? Rebooted the hub? If you post your modem stats here we can see if they look ok or not but probably best to get a ticket raised with VM as well.God Virgin has been terrible today where I live I'm on 200mb and I'm only getting about 8mb also when I do a speed test they only go up to 100 is this standard?
Had another engineer visit recently to try and fix my slow speed. The engineer changed power levels again. Still no fix. He clearly saw that my speed was no where near what it should have been but didn't really seem bothered about it
Since his visit, I have had lots of pre and post RS errors, so I might have to get another engineer out
Started another BQM tonight, how's it looking
The superhub 4 arrived today. All installed, no different at all though in terms of speed. Still much slower than what I should be getting (150mbps on 600mb package)
This is my full BQM from yesterday, how does it look?
https://www.ispreview.co.uk/index.p...roadband-engineer-shows-how-it-all-works.html
Interesting to see how it all connects up![]()
Thats a shameNot anymore - they made the videos private.
Good deal im paying £35 a month which has gone upto £38.50 for M350Hi all,
I've recently upgraded from a very stable BT ADSL package (40 down / 10 up) with BT @ £27 a month to Virgin Media M500 broadband only (500 down / 36 up) @ £36 a month (18 month then £52 thereafter) via compare the meerkat offer; hopeful £115 cashback and £75 amazon voucher..
Thankfully they provided the Superhub 4, opposed to the 3 which I'd read numerous issue about!
Have been quite impressed with the speed + stability thus far.
I'm consistently pulling close to the advertised speeds wirelessly via the 5ghz channel.
One issue, though not technically Virgin Media's is that my powerline adapters; despite being rated at 1 gigabit (though allegedly 600mbps via tp-link PLC utility) appear to be limited to to 175 down / 36 up.
Apparently I can contact Virgin Media and they can relocate the cable entry point, supposedly free of charge.. which I've considered to the office upstairs where all my ethernet devices are located.
Unless anyone on here has any other ideas?![]()
