Underboss
- 20 Oct 2002
- Oxfordshire / Bucks
no update for me yet
No I hadn't changed it, and I'm running an honor 3 with wifi6 just for the quest
Is it not set to 0 by default anyway? When i open up the debugtool it shows as 0 for me unless you've changed it previously?I got the update but air link doesn't work properly for me. I have all the requirements met but when I click launch, it does launch but the view is only a square which moves in front (not flat screen, still vr, but fov is just a square rather than 360) of my face and I cant select anything accurately at all.
edit: i fixed it, i had change the bitrate myself in oculus debug tool. setting it back to 0 fixes my issue
Changing it improves visuals over the link cable. Shame they use the same setting for both.Is it not set to 0 by default anyway? When i open up the debugtool it shows as 0 for me unless you've changed it previously?
Airlink is up and running
Select it in the beta tab on the desktop oculus software and then it will appear on the headset
Just given it some testing and it works well, Virtual desktop performs better still for me but that's probably as it's running 120hz and Airlink is currently 90hz
what will be really interesting is when/if 120hz airlink is enabled, running ASW with 60fps - 120Hz... ASW artefacts should be less noticeable than from 45fps (less motion to calculate for a given frame, less to get wrong), you get the buttery smooth 120Hz feeling, and a relatively easy frame rate target of 60fps + ASW headroom.
Would be really interesting to compare a “native” 90fps vs 60->120 ASW.
So I have a pretty crappy bog standard Plusnet router downstairs and my pc upstairs. If I was wanting to take advantage of airlink could I just get a standalone router to put in the same room as my PC or would it have to be wired up to my Plusnet router?
Guessing it means I wouldn't be able to play online though?Yeah you can do that. I bought a TP-Link Archer C6 for about £35 and have that plugged into my PC solely for VD/Air Link. No need for it to be hooked up to your plus net router.
Just on the WiFi bud.It depends, how is your PC connected to your Router downstairs?
