@nvidiamd how did AMD more than double the performance of the 5700XT at similar power consumption on the same node? How did they do that?
How is it that a 16 core CPU can exist with higher per core performance than its 8 core competitor with half the power consumption? that's 4 times the performance per watt, how is that possible?
What you say cannot be done has been done more than once.
It is not the same power consumption. The 6900xt is almost 100W over 5700xt. That is around 30% more power than the 5700xt for 80-100% more performance. I am not sure they can afford that every generation. Maybe for the next gen, i hope they will go full power, something like 15-20% more power for 40% raster/100% RT increase.
I already told you the best thing RDNA2 did was the improvement on perf/watt. It is very impressive and when we look at Ampere we see the perf/watt improvement over Turing is almost unexistent. The biggest gain from Nvidia comes from adding more hardware and increasing the power usage.
