**** Official Microsoft Flight Simulator Thread ****
24 Sep 2013
Exmouth, Devon
I think you’ll find it’s more expensive actually
https://aviatek.com/collections/all/products/av-g1000-complex-desktop-trainer
In this day and age, I’m surprised they can’t make a consumer level model for flight sim with a retail of £200-£300. They’d sell like crazy at that price.
Flip me, that's half a real PPL A. May as well get a licence.
If you are into flying the big birds, you could join a Virtual Airline too. Some of them such as BAVirtual and Delta Virtual are excellent.
WoW - didn't know that was a thing.
20 Dec 2004
Well, as I've just had it confirmed I can't play any sport for 2-3 months I've gone and bought a Rift to keep me occupied. Looking forward to giving some MSFS a whirl later.
Permabanned
15 Apr 2010
Did you have to pay import duty & customs fee?
Most of my Aviatek gear was actually purchased pre-brexit. Only the MFD panel was purchased afterwards, at a cost off just under 1700 Euros and £307GBP import and fees once it landed.
I still have the centre Audio panel to get, so I'll be paying import on that too eventually.
Although its not in the picture, I also already have the AV GCU 475 - the small FMS Keyboard panel.
21 Jan 2016
Sim update 4 patch notes:
RELEASE NOTES 1.16.2.0
Some packages in your community folder may not have been updated and, as a result, may have an unexpected impact on the title’s performance and behavior.
Please move your community package(s) to another folder before relaunching the title if you suffer from stability issues or long loading times.
We performed some optimization for the initial full download of the title so the base game is only 83GB instead of +170GB
NAVIGATION
  • New AIRAC cycle 2105 has been implemented
  • FAA data has been implemented to our navdata solution
  • Departure gates are now saved in flight plan (.PLN) files
  • Fixed a crash and other issues when selecting a parking space as arrival and no set departure
  • Fixed some Live Air Traffic aircraft using the wrong model
  • Fixed an issue where some Live Air Traffic aircraft had broken callsigns
  • Increased the density of Live Air Traffic
  • Aircraft that are not on the ground but that have an altitude of zero will now appear at a default altitude of 5000m
  • Live traffic stability has been improved
  • ATC phraseology improvements to FAA standards (wording only)
WEATHER
  • Reduced weather data bandwidth
  • Improved precision of live snow coverage
  • “Visual Effect Only” in assistance now does properly deactivate other weather effects
  • “Visual Icing” has been renamed “Icing” in the devmode because it impacts the whole icing system
  • “Icing” in DevMode only changes visual effects if “Visual Effect Only” is activated
  • Ice constant decay is no longer ignored outside of frost conditions
  • Accelerated pitot icing model while making it slower to defrost
  • Fixed pitot icing not scaling with the number of instruments
  • Fixed overspeed controller vibrations not affected by pitot icing
  • Decrease structural icing rate by a factor of 15 for severe icing (6 for moderate)
PLANES
All planes:
  • Added altitude interception for PITCH HOLD mode
  • Increased native induced drag amount and improved induced drag precision
  • Autopilot no longer flies toward a Waypoint removed from the FlightPlan
  • SimConnect injected traffic (VATSIM, IVAO) should now be displayed in HTML/JS instruments that have traffic displays as well as on the VFR Map
  • Fixed simvar acceleration not taking impacts into account and returning wrong values on ground
  • Writing back corrected acceleration values after impact resolutions so that they are exact when pulled as a simvar
  • Flaps, stall, wing and fuselage updates of flight model
  • More cleanup of the flaps system. Support multi systems with different number of levels and max angles
  • Increased threshold to avoid trim fight against elevator to 50% (corresponds to disconnect threshold)
  • Changed elevator AP with trim to avoid fighting against user input when user input is >50% on elevator
  • Allow setting the empty CG position out of limits
  • Fixed more audio not playing on large aircraft
  • Fixed Autothrottle sometimes disabled by AI
Turboprop:
  • Improved tools to tune prop drag on constant speed & turbo propellers
  • Removed fake and completely wrong ITT simulation when prop is feathered or reverse
  • Fixed reverse thrust problem with propeller (no support of negative beta & induced wind)
  • Added prop lever debug on engines debug page
  • Fixed torque increasing with altitude because of N1 / Corrected N1 confusion in FSX turboprop code
  • Fixed crash bug when scrolling Daher TBM 9300 Flight Plan pag
  • Torque fine adjustment per POH for the Daher TBM 930
  • Updated stability and inertia for the Daher TBM 930
  • Adjusted sea level max torque on the Daher TBM 930
  • Turbine fine tuning: ITT, Torque, Performance, and Fuel Flow on the Daher TBM 930
  • Flight model update for handling on the Daher TBM 930
  • Ground level max torque and torque limiter setting updated. 100% max with inertial separator; 112% max, limited to 109% without inertial separator on the Daher TBM 930
  • Reduced effect of inertial separator from 25% TQ to 12% TQ for the Daher TBM 930
  • Tuned stability and inertia on the Beechcraft King Air 350i
  • Tweaked Idle RPM from 1030 to 1060RPM for the Beechcraft King Air 350i
  • Adjusted max sea level torque on the Beechcraft King Air 350i
  • Tuned Beechcraft King Air 350i turboprop engine: ITT, Torque, Fuel Flow and other minor changes
  • Added ITT debug to engine debug and added density on fuel flow table for turboprop engines on the Beechcraft King Air 350i
  • Fine tuned fuel consumption per the POH at IDLE, 12000ft cruise and 18000ft cruise on the Cessna 208 B Grand Caravan EX
  • Fixed ITT, Throttle to Torque Ratio, and Garmin color bands for ITT and TRQ on the Cessna 208 B Grand Caravan EX
  • Pass on stability and inertia on the Cessna 208 B Grand Caravan EX
  • Fine tuned Fuel Flow per altitude and ajusted sea level max torque on the Cessna 208 B Grand Caravan EX
  • Turbine Torque fine tuned per POH on the Cessna 208 B Grand Caravan EX
  • Control surfaces & handling improvements on the Cessna 208 B Grand Caravan EX
  • Prop lever of the Cessna 208 B Grand Caravan EX can now be set in feathering range
Others:
  • Weather radar now displays precipitation instead of cloud coverage
  • Fixed contrail behavior on player’s aircraft during windy conditions
  • Contrails are now displayed for applicable AI traffic planes
  • Reduced rudder authority based on the Cessna 152
  • Stability and inertia pass on Cessna 172 Skyhawk and Cessna 152
  • Flight model handling update for the Cessna 152
  • Fixed Cessna 152’s rear wheels not touching ground
  • Pass on engine power & propeller drag. Fine tuned max speed, cruise speed, climb speeds, glide speeds and other minor tweaks on the Cessna 172 Skyhawk
  • Flight model tuning of Cessna 172 Skyhawk (handling, induced yaw, roll and stall)
  • Fixed water on windows and tail color on LOD5 for the Boeing 787-10 Dreamliner
  • EICAS now displays “CLB” instead of “CL” when the thrust levers are set to CL in the A320
  • Fixed an issue which prevented copilot from autocompleting the Securing Aircraft page on the Diamond DA40 TDI
  • Improved propeller drag and engine drag tuning for the Diamond DA62
  • Flight model handling update on the Diamond DA62. Made engine effect more important by adjusting rudder surfaces
  • Increased rudder stability slightly and fixed engine stall in air at low speeds on the EXTRA 330LT
  • Added a notch more dihedral to increase induced roll a little on the EXTRA 330LT
  • Fuel Pressure gauges now display correct levels of pressure on the EXTRA 330LT
  • Fine tune on the 103Solo Engine and implementation of engine clutch below 2100 RPM
  • Fixed FS Livery on Cessna Citation Longitude disappearing too early on LOD6
  • Corrected Pipistrel Virus SW121 flaps animation which would not properly play for negative flaps values
  • G3000 : Map zoom level is now kept constant between Regular and Weather map
  • G1000 : Airspaces are redrawn uppon change in map orientation
  • G3000 : Fix PFD display error when a DirectTo is requested
  • Fixed aircraft spawning with glasscockpits turned off randomly
  • Fixed FlightPlan displaying passed waypoints when canceling a DirectTo
  • Fixed FlightPlan guidance not re-engaging properly when DirectTo is canceled or reached
  • Fixed G3000 and G3X MFD TopBar displaying True Bearing instead of Magnetic
  • Fixed overspeed strip being too low on airspeed tape
  • Fixed bug where the flightplan was not displayed properly if the flight was started directly on approach
  • Fixed VFRMap not updating approach according to FlightPlan
  • Tactile glasscockpits scrollbars are bigger and can be interacted with more easily
INPUT
  • Fixed resetting position peripheral input position when user exits the pause menu
  • Fixed the unresponsive specific axis on Honeycomb Bravo Throttle
  • Fixed default mapping for the CH Eclipse Yoke
  • Fixed default mapping for the CH Fighter Stick
  • Fixed default mapping for the CH Flight Sim Yoke
  • Fixed default mapping for the CH Fighter Stick Pro
  • Fixed default mapping for the CH Pro Pedals
  • Fixed default mapping for the CH Pro Throttle
  • Fixed default mapping for the CH Throttle Quadrant
UI
  • Community Folder Addons will now show up as Installed in the Content manager
SDK/DEVMODE
General:
  • Coherent GT’s debugger is now included in the SDK
  • Speed restrictions and RF center fix information is now available on airport facility procedure data via the JS facility listener
  • JS facility listener LOAD_* calls now return bool to indicate whether or not an ICAO can be loaded
  • Facilities.getMagVar added when JS facility listener is loaded which allows one to get the mag var for a given LatLongAlt
  • Maximum number of JS BingMap views increased from 5 to 9
  • Ability to intercept and mask key events has been added to the JS key event listene
  • Preventing the game from crashing if too many virtual netbing maps were created
  • Fixed the installation of 3DS Max tools
  • Fixed the font displayed in the release notes window
Documentation:
  • Creation of an Xbox X|S dedicated page in the documentation, which gathers the latest info & best practices to port content on Xbox.
  • Visual Effects documentation has been added along with a sample. A video tutorial will be added soon.
  • Major updates were made to The Project Editor section:
  • Updated main page with more information
  • New section for Project Asset Types (WIP)
  • New section for the various project editor menus: Project, Edit, View
  • Updated Marketplace Data page
  • Updated Export Window page
  • Content Configuration now has a section dedicated to Flights And Missions:
  • Initial documentation for Flight Plan Definitions
  • Initial documentation for Flight Definitions
  • Initial documentation for Event Trigger Definitions
  • Initial documentation for Weather Definitions
  • A page has been added documenting the new SimObject Stats window.
  • A page with samples to illustrate model optimisation has been added specifically for the Xbox, although the samples shown are relevant to everyone creating add-ons.
  • A page has been added for Submodel Merging in the 3D Models section.
  • The Airport Tutorial has been updated to show the Airport Wizard for Creating Or Replacing An Airport
  • Page on Aircraft Texture Mapping now has a section describing how to set up Ice
  • Page on the Package Tool XML Definitions has been updated with more information.
  • Page on the DA62 sample added to the Samples And Tutorials section
  • New engines.cfg and flight_model.cfg setting documented
Project Editor:
  • Renamed package inspector “+” button into “Add asset group”
  • In the Marketplace Data Editor, fixed a crash when loading empty thumbnail
  • Fixed simvar index being lost when loading a file
  • Disabled a false positive error message box that appeared randomly when building aircraft packages
Scenery Editor:
  • Fixed a crash when editing runway terraforming profile
  • Fixed ‘`’ char being filtered in taxiway sign content text entry.
  • Fixed the “add custom asset group” window which wouldn’t close when creating a new non-templated asset group
  • Fixed the windsocks with wrong orientation
  • Fixed infinite loading for light presets with no mesh
  • Fixed issues with water polygons
Aircraft Editor:
  • Fixed a potential crash when converting old .air file.
Visual Effects Editor:
  • The Visual Effects Editor is now available! You can now create your own effects. We prepared a video tutorial and complete documentation that can be found at http://docs.flightsimulator.com 2 !
Flight Model:
  • Added elevator_lift_coef, rudder_lift_coef and fuselage_lateral_cx to give aircraft creators better control over plane stability
SimConnect:
  • Added new SimVar “GEAR SKIDDING FACTOR”
Audio:
  • On Wwise Sample Project: Fixed shared IR convolution medias not loaded in remote
  • On Wwise Sample Project: Added Built-in Emitter & Listener cone game-parameters
KNOWN ISSUE
  • You may crash when exiting VR mode. This issue is being investigated but we suspect OpenXR preview runtime (v106) may be involved. So if you experience this problem, we recommend you revert to the official public runtime (v105).
29 Nov 2009
Thanks.
28 Feb 2012
Herts
“We performed some optimization for the initial full download of the title so the base game is only 83GB instead of +170GB“
That’s some optimisation! I hope they haven’t compromised anything?
21 Jan 2016
I think the way it previously worked was downloading the original base game, then all the changes on top. They have now basically just updated the initial download to a more up to date version.
Install size itself is unchanged.
30 May 2021
Epsom
Hey all, I use FS2020 whilst sat on my couch mostly controlling with an XBOX controller and keyboard.
The keyboard is an all-in-one keyboard and trackpad for media pc's. The Logitech K400
The thing is I can't seem to find a way to zoom in and out of the globe in flight simulator which is a problem.
Does anyone know a way around this?
**fixed the above using two fingers up/down on the trackpad to zoom in/out**
1 Jun 2010
London
Hi guys
So today I purchased Gamepass for PC and installed Xbox App and FS2020. The game is installed in D:/ (Samsung 960 EVO 1GB)
Medium Settings: with AA and Motion Blur OFF
Live Air Traffic
Playing on 2560 x 1440 144Hz
My specs are as follows:
[email protected] (Adaptive Mode)
64GB DDR4 3800MHz
GTX 970 Stock speed
When running the game I was getting 11-13FPS and the following message: "Limited by Main Thread".
I opened up HWinfo and noted CPU was at default speed of 1.2GHz. CPU-Z was also showing same speed of 1.2GHz.
It appeared that game load was not forcing CPU to turbo boost to 4.7GHz. However when stress testing CPU with y-cruncher the CPU immediately went to 4.7Ghz. :confused:
The result was same even if I change CPU affinity to high.
Please can someone help me with this issue?
22 Dec 2004
Rugeley, Staffs
Hi guys
Live Air Traffic
64GB DDR4 3800MHz
GTX 970 Stock speed
Hi,
The game is full of optimisation issues unfortunately, a lot of them are MS side, not really a lot we can do about it from this end, you might also be a bit limited by your Graphics card.
People with top end systems with RTX3080s are struggling.
19 Oct 2002
Jersey
Hi guys
You've set power settings to full performance?
21 Jan 2016
perhaps try in nvidia control panel ---> manage 3d settings ---> program settings -----> Microsoft flight simulator try setting the power management mode to "prefer max perf"
