Can`t see that update on my pc anywhere so i don`t think i had that oneProbably the scsi driver as thats been reported as doing something similar.
Here's how you enable it mate.Quick question? @LtMatt - I have a 6700 XT and just enabled resizable BAR support in my bios. It enabled a further 2 other options: '4G Decoding/Crypto Mining' and something called 'Restore PCIE Registers' - All good or should one of the options be disabled?
https://www.amd.com/en/technologies/smart-access-memory
How are you finding the 6700 XT and which card have you got?
I've got one on the way to me in a few days for a play.
No i don't think you need to touch that option.Done exactly as described, however it enabled a third option upon saving: Restore PCIE Registers? I assume this is also required for system changes.
I have the Powercolor Red Devil 6700 XT and blown away by it to be honest, cool and stupidly slient!
You can check if its enabled under Device Manager > Display Adapters > Right Click Properties > Resouces > Does it say Large Memory Range? If so then you are good to go.
I've not personally heard of it and don't see it in my BIOS, but if it's working all good.Correct, I can see this option. I'm not having any issues, all is well. When enabling the 2 options this 'Restore PCIE Registers' popped up when saving the BIOS, didn't give me an option to disable it so I assume it's needed somewhere as part of the feature.
Leg-end or legend?![]()
