** The Official Days Gone Thread **
You miss out on the upgrade injectors and camp reputation if you do.
I believe they are an integral part of the game, but I stand to be corrected.
They are, if those are all done, and the hordes and most everything else there is another 'ending' after the proper ending. I would think others have discovered that ending although not seen any mention about it. I have yet not bought the game but know there is from having casually watched a streamer playing it when it first come out on PS4 ages ago.
Another tip is to craft stamina cocktails they will give stamina back when used so make running from hordes a bit easier. A LMG will work better to if you got one.
Craft proximity bombs and attractors, They will swarm towards it and you can take loads out with any explosives :)
I've finished the story and now clearing up the hordes, they are good fun and can be quite tense.
I found the bombs, exploding fuel tanks etc etc kill so few enemies with remote bombs being the most useless. Got through by cheating.
Maybe I was thinking of it being like the Xbox 360 CE software. Isn’t there a native Windows driver as part of the PlayStation Now app?
Got it yesterday and played some, seems promising though I can see it getting a bit Ubisoft-y down the road but looks and runs pretty damn good so far.
What gpu temps are people getting with this?
All my other games I get between 60-70 but Valhalla is about 78=80 and Days gone is the hottest at 78-86.
my case is spacious and I clean the inside once a month ...
Playing NG+ and things are much easier once you have some half decent weapons, even did a horde today which was fun (ish).
