Nice clocks, though memory is on the lower side for OC. Are these stress tests stable?Testing out performance in the new Cod Black Ops 24 player game modes.
Any higher on the memory causes performance degradation, and yeah the servers are laggy sometimes.Nice clocks, though memory is on the lower side for OC. Are these stress tests stable?
Also, saw a lot of hitches. I am presuming those are because of server issues.
The COD Skill Based Matchmaking system often puts my in high ping severs these days.
I had half my cores disabled as a test on the 5950X so HWINFO decided to display the BCLK clock for some reason.What is the 5950 100Mhz metric above the FPS display about?
Very nice! He’s using a hardware mod to go past the default voltage limit of 1.175v, he’s at something like 1.250v. Considering how close my score is to his, I’d like to think I could get close with all that extra voltage.gonna leave this here - try and beat him
Nice looking build.Just wanted to introduce myself. I got a Sapphire Nitro+ 6900 XT installed about a month ago (upgraded from ASUS 6700 XT OC) and have been enjoying it with my old MSI MEG Godlike Z490 (PCIe 4.0 x16 slot 1) with new Intel i7-11700K, Corsair H115i AIO, 32GB Trident Z Neo 3600MHz RAM, and Samsung EVO plus 2TB NMME drive. I decided not to use the included MSI Godlike PCIe 4.0 M.2 daughterboard with a 980 Pro, as the PCIe 3.0 with EVO plus is fast enough and I wont have the added card blocking airflow (Samsung magician puts SSD speeds at 3494/3309). I think the case is a Corsair 4000 (got used from my son), and I'm using a new Seesonic 850W 80+ Titanium PSU. I topped it off with a Corsair Harpoon mouse and Logitech G915TKL RBG keyboard.
I'm still messing with OC settings an +15% draws about 303 watts. I have not used MPT or GPU-Z until I am more experienced. I have max GPU speed set to 2605 or so, and it will peak there but it usually runs between 2350 and 2480 Mhz with an average around 2390 MHz. It runs better when voltage is dropped from 1175 to 1150, but it seems to slow down in benchmarks or Time Spy will simply fail to complete when I under-volt in AMD Radeon Software below 1150. Also, in stress tests it will achieve 2128-2140 Mhz VRAM when set to 2150, and seems stable with settings at 2150, but it will just pick whatever speed it wants between 2100-2150 MHz when it's set to max. The 3DMark website will show that my VRAM is speeding up to 2120 or so, but the graphs show it's nailed at 1800 Mhz.
My Forza 4 1440p Benchmarks beat my son's MSI Gaming X Trio RTX 3090 with 188fps vs 165fps, until he upgraded from a 5800X CPU to a 5950X with SAM enabled, and now he is catching up at 175 fps. I believe I have ReBar turned on in BIOS.
I'm not sure why I can't under-volt more and get more Mhz from the GPU, but it seems fast enough - with Time Spy over 18,000 and Port Royal was about 10,500 I think. Anyway, thanks for reading.
My 6900 XT with Forza Horizon 4 (on 4K 60 monitor running benchmark for 1440p)
My Son's 3090 after SAM (he is on a 165Hz 1440p monitor)
Nice looking build.
Your scores are good for the 300W power limit of your GPU. If you want to improve your scores further and achieve higher clock speeds, you'll need MPT to raise the power limit.
There is a Forza Horizon 4 benchmark thread here so you can post you and your sons scores. Check the OP for the settings you need to use - essentially everything at maximum bar reflection quality at Ultra.
How did you find the 6700 XT? I am using both a 6900 XT and a 6700 XT and was quite surprised how fast the 6900 XTs little brother was.![]()
I've used most of the current highend cards @DocJekl and the 6900XT is right up there, excellent excellent cards! Enjoy![]()
Welcome and on TROH.
The Roll of Honour.
Thanks! I wish there was a “like” button for posts. I worry I’d be rude here if I don’t respond to every post directed at me since I can’t click on “like” - is that a problem here?
Date 04/06/2021, Make Sapphire Nitro+, DocJekl, Link
Date 12/05/2021, Make Sapphire Nitro+, Ryder_1990, Link
Date 07/05/2021, Make Sapphire Toxic, Bazooka301, Link
Date 02/05/2021, Make PowerColor Red Devil, Sky01454, Link
Date 16/04/2021, Make AMD Reference, Chud_Jenny, Link
Date 15/04/2021, Make AMD Reference, Scramz, Link
Date 14/04/2021, Make Gigabyte Gaming, Scramz, Link
Date 30/03/2021, Make Sapphire Nitro+, BKUK, Link
Date 18/03/2021, Make Sapphire Nitro+, xR00Tx, Link
Date 16/03/2021, Make AMD Reference, Sumanji, Link
Date 11/03/2021, Make PowerColor Red Devil, mikehhhhhhh, Link
Date 09/02/2021, Make AMD Reference, Pourma, Link
Date 06/02/2021, Make PowerColor Red Devil, John Mike, Link
Date 04/02/2021, Make PowerColor Red Devil, djbully, Link
Date 04/02/2021, Make Sapphire Nitro+, atomic7431, Link
Date 03/02/2021, Make AMD Reference, snips86x, Link
Date 03/02/2021, Make XFX Merc 319, LtMatt, Link
Date 03/02/2021, Make AMD Reference, SumpNut, Link
Date 03/02/2021, Make Asus Strix LC, JediFragger, Link
Date 31/01/2021, Make PowerColor Red Devil, littlepuppy, Link
Date 30/01/2021, Make AMD Reference, ExRayTed, Link
Date 27/01/2021, Make AMD Reference, wookiee87, Link
Date 26/01/2021, Make AMD Reference, muziqaz, Link
Date 26/01/2021, Make AMD Reference, Conanius, Link
Date 24/01/2021, Make PowerColor Red Devil, eeii, Link
Date 23/01/2021, Make PowerColor Red Devil LE, Too Tall, Link
Date 15/01/2021, Make AMD Reference, Overlag, Link
Date 14/01/2021, Make XFX Merc 319, Seanoog, Link
Date 14/01/2021, Make PowerColor Red Devil, Heofz, Link
Date 13/01/2021, Make XFX Merc 319, ch99mr, Link
Date 10/01/2021, Make AMD Reference, Breezer, Link
Date 10/01/2021, Make XFX Merc 319, ronski, Link
Date 07/01/2021, Make AMD Reference, Biffa, Link
Date 06/01/2021, Make PowerColor Red Devil, heartburnron, Link
Date 04/01/2021, Make Sapphire Nitro+, Mister_tangerine, Link
Date 01/01/2021, Make Sapphire Nitro+, Jumper118, Link
Date 01/01/2021, Make AMD Reference, Jumper118, Link
Date 31/12/2020, Make AMD Reference, NathG79, Link
Date 30/12/2020, Make PowerColor Red Devil, Nugsy88, Link
Date 27/12/2020, Make AMD Reference, LtMatt, Link
Date 26/12/2020, Make AMD Reference, Abhishek Shukla, Link
Date 24/12/2020, Make AMD Reference, ch99mr, Link
Date 24/12/2020, Make Sapphire Nitro+, hornytoe, Link
Date 23/12/2020, Make AMD Reference, Diplodocus, Link
Date 23/12/2020, Make AMD Reference, DeathStorm, Link
Date 23/12/2020, Make PowerColor Red Devil, Jonnym28, Link
Date 17/12/2020, Make AMD Reference, DustyMiller, Link
Date 16/12/2020, Make AMD Reference, Curlyriff, Link
Date 16/12/2020, Make AMD Reference, Chewie, Link
Date 16/12/2020, Make AMD Reference, Too Tall, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Radeon RX 6900 XT.
It was fine you should be okay.So I looked at my reply to a question asking where I found my 6700 XT, And I’m worried that I was hinting about where I got it without saying where I got it, and then it might be violating rules. But I tried to edit the hints out and it won’t let me do it, so hopefully I don’t get banned because I don’t understand the rules here.
Welcome to the forum, holy RGB Lol!Any questions about Aorus Master be my guest
https://i.~ibb.co~/zQTx2b4/IMG-20210604-005546-346.jpg
