- 25 Nov 2005
Surely that's because the crystal is one flat piece of glass though hence the lack of structural strength on impacts whereas a case is designed a specific way to increase that structure?
There are also at least 5 or 6 brands who have sapphire cased watches and have done for some years, not heard of any breaking due to lack of strength!
I suspect the material ingredients used o create the sapphire aren't exactly the same as sapphire used in crystal either like how ceramic watch cases are not the same ceramic you get in cookware or bezel inserts and are considerably stronger as a result. Zelos is one brand that I know if they choose to use a material, it's been tested by them to some extreme too.
Not sure just going off what I've read that Sapphire is great for being scratch resistant but it can crack if dropped due to it being very brittle, assumed it would be the same for a case built entirely from it as well, does anyone have a Sapphire case they wish to put to the test ?
