- 11 Mar 2005
@WJA96 - another question please!!
I've got port forwarding set up through DDNS on my Hik NVR. My NVR has a static IP Address.
I used to use iVMS 4500 on iOS - and it still works fine..
I've now installed HikConnect - and can still see the cameras through my NVR - as I added them by DDNS.
I can't see the Doorbell cam however, and I think - from my scouring of the web - that - I can simply remove the static IP address - and use dynamic addressing instead? Then I can add the doorbell and NVR to my device list on Hik Connect on the web - and that should solve it??
Or is there a simpler way? I quite like having the DDNS - but I suspect that HikConnect makes this redundant now?
Cheers again...
ps.. installed AX Pro yesterday - was a doddle!
Cheers again...
