aim assist doesnt work on mulitplayers, its just incredible skill ...... or haxThe most surprising thing I've noticed in cross play lobbies is the fact that some console/controller players are better than the PC ones. I assumed the kb&m players would dominate but apparently not, aim assist maybe?
Not sure where you're getting your info from but it's simply not true. Aim assist is definitely a thing on console.aim assist doesnt work on mulitplayers, its just incredible skill ...... or hax
Its not console specifically. You can connect a pad to PC and use the same aim assist options as console playersNot sure where you're getting your info from but it's simply not true. Aim assist is definitely a thing on console.
aim assist is on for all multiplayer and you can buy a little gizmo that removes all recoil and add extra assist as well, turns burst guns into auto ect
but there are some really good controllers players but lots now use mouse and kb as well
oh really i, i tried to play multiplayer with my xbox controller and when i went to see if aim assist was on it was all greyed out, but on single player i could toggle it.aim assist is on for all multiplayer and you can buy a little gizmo that removes all recoil and add extra assist as well, turns burst guns into auto ect
I know in warzone its definetly on but mostly all it does is slow your sight down when your on target
but you do need to do the hard work and get it close to target
any point updating with a 129gb odd download on battlenet? completed it ages ago so wonder what 129gb has? lol
Modern Warfare and Warzone is 136GB combined so would imagine if Cold War is similar in size it will be entire map changes that require all files to be redownloadedWell there seems to be new maps added every few days recently.
129GB sounds like Campaign, multiplayer and Zombies
Didn't want to pollute the Modern Warfare thread with a different gameTh th th th th thread revival!
