- 28 Dec 2017
- Beds
Thanks for replies so far! The plan is to run it for an hour or two before bed and keep the room sealed. If it has to come back on when dawn starts heating the room up, that might be tolerable if I've already had some good sleep.
My house is overly insulated from inside so basically traps heat if there is sunlight getting in. If I get it cool at night I'm hoping it stays cool ish. Office reads 28.6° right now and it will heat up further when sunset pokes into the windows.
Makes the window vent kits fit perfectly with zero faff...
