- 9 May 2014
I know you paid a good price (lucky sod) for Gpu was it from retailer or private seller
A retailer that starts with C and ends in L and only because they gave you a 15 min grace period if you got the card in your basket.
I was thinking more along the lines of something is not making good contact and is overheating.Not sure why they flagged I do wonder if the temp one is because Im Watercooled so it picks up no fan RPM?
Monitor is freesync and I have vsync disabled in nvida 3d settings
Install and open hwinfo and run a benchmark then post this part from the GPU section.
You can see the software name and version info at the top.What software are you using I installed HWinfo and it looks nothing like this at all.
I'd remove the block and repaste the die, make sure you use plenty of paste on it not just a thin spread like you do on a CPU.
What paste do people reccomend I've always gone with Thermal griz kryonaut.
