Your first posts as long term members
You daft bugger, I meant the last bit :)
Oops, I should have put my glasses on, that's not Bainbridge :)
:p there was a joke there but I didn't realise the email extension I used was blocked. I guess that proves his email was indeed banned. (it was the part of a multi-function printer that doesn't do the printing).
I wasn't allowed to join back in 06 because I didn't have an approved email address, but I guess the rules were then later relaxed.
We used to insist on a proper ISP email address but that was when every single sign up was manually checked.
My intellimouse is still working, can I have a free 10,000 thread count upgrade please?
Although all OcUK prices are pre-discounted for your convenience, I can give you a 10,000 post count discount if you want. That'll take you down to just under 700 posts, how's that? :D
It was on the old forums (purple and white default vbulletin theme I think?) and probably asking about upgrades from a Celeron 400 to an Athlon Thunderbird. :D
Ended up buying it with a Delta screamer fan... one of the worst decisions ever.
My first posts will be gone as they were pre 2002 although they were very likely drivel as that's what I do. Unless it's about football in which case it would've been 100% correct as I'm never wrong about football.
Thats OK, if I get the MM pass on 1000 posts. :D
I suspect a lot of peoples actual first posts are long gone, also there was a forum reset at one point afaik
This, I cant even remember my original username and logon details.
Pretty sure my first post was about the pencil trick to get the Athlon xp up from 1ghz to 1.4gz.
First post after I cam back in 2005
https://forums.overclockers.co.uk/posts/4127618/
was running a ATI Radeon X800 XT 256Mb with a Athlon 64 3200 Winchester cpu back then.
