I might just do that. No updates then. phew. Don't think I can run much on it though. Maybe send a couple emails from command line that would be about it.
It is surprising how far you can push DOS, pure DOS without compiled tools, etc. with a bit of out the box thinking - though I've not really found a reliable way to read mouse data yet without using a compiled helper exe.
EDIT: Though a stock way to properly tails standard out from an exe would help as well - as the pipe support there is a bit deficient for real time use.
A thread about stripped down Windows 10 and MSMG ToolKit doesn't get mentioned even once? I use it to create my images and it strips out exactly what I want.
There is a slight learning curve, but obey the readme.txt and you should be fine.
