Permabanned
- 9 Aug 2008
awesome thank you, testing LTSC in Hyper-V again.
been using ltsc for a year now working fine.
 I love how stripped down it is.  Doesn't even have a browser to start with lol
 I love how stripped down it is.  Doesn't even have a browser to start with lolWhy not install MS-DOS? That is slipstreamed as you can get
It is surprising how far you can push DOS, pure DOS without compiled tools, etc. with a bit of out the box thinking - though I've not really found a reliable way to read mouse data yet without using a compiled helper exe.
EDIT: Though a stock way to properly tails standard out from an exe would help as well - as the pipe support there is a bit deficient for real time use.
I do the same, can remove most things from itA thread about stripped down Windows 10 and MSMG ToolKit doesn't get mentioned even once?I use it to create my images and it strips out exactly what I want.
There is a slight learning curve, but obey the readme.txt and you should be fine.
I agree but you cannot get a license for LTSC can you or do you use the evaluation period and then re install? I am currently usingW10 ProA default ISO is better than having to strip crap out constantly.
I stopped doing that a while back.
I thought that was the case, not really an option then for most peopleBusiness only MAK or KMS activated.
Just installed this and got an extra 565 points in TimespySoooo.... benchmarks ?
 still not in the top 100 though
