An hour of Quake II RTX had my memory go up to 100C, GPU still in the 70's.
At least there is a three year warranty, do you have to register for this?, puts me off fitting new pads or a water block
100c that's ok as long as its under 110c
	Such a good card I had the 3070 version and it would sit a 50-55c hard gamingFinally have the 3080 Ti I was after from the very beginning (non-scalped edition).
Did you get the card from OcUk?
Got my Gainward Phoenix on Thursday. Out with the old workhorse eVGA 780 3gb, in with the new 3080ti 12gb. Little bit disappointed the Geforce RTX wording doesn't light up, I thought it did but otherwise happy.![]()
Also bought a Gigabyte G34WQC 1440p 144hz. Still not sure I have it set up right as I'm getting "only" 100fps average on RDR2 max settings @ 3440 x 1440p.
Just installed 20 minutes ago
Gonna let it bed in for a little before the games comence!
Try it.Just ordered a 3080 Ti GameRock OC. The recommended PSU wattage is 850W. Do you guys reckon i'm fine with the Corsair RMx 650W gold?
The card can use almost 400 Watts. So if you run it at stock then no. You want a good 850w PSU as a minimum if you want a stable system and you have not said what the rest of your system specifications are.Just ordered a 3080 Ti GameRock OC. The recommended PSU wattage is 850W. Do you guys reckon i'm fine with the Corsair RMx 650W gold?
