Depends if you hog the right lane with ditchfinders on or notJust more ***** to go wrong. If your brakes fail you could still stop a car with the handbrake. Can you still do that with this new button brake?
Yes and its not a button either but a switch you pull. Its an argument that's pretty academic anyway as the majority of drivers seem unable to use a manual one these days, god knows who taught them to drive...Just more ***** to go wrong. If your brakes fail you could still stop a car with the handbrake. Can you still do that with this new button brake?
Probably as you can still use it if your brakes fail (if still using a cable).
Electric hand brakes can still be used as a last ditch emergency brake as they use a mechanical actuator to apply the brake shoes rather than hydraulics. IIRC the toggle on a Insignia had to be operated 3 times in quick succession to activate the emergency function.
Though with modern cars, you've got to be having a really very bad day if you lose all hydraulic function with dual / triple circuit brakes.
Not really, more cars now also have electric assist rather than vacuum. Lossof hydraulic line pressure is the situation either system is there as a backup for.
doesn’t stop you making stuff up though hey Nasher.
Why would you want to move a car with no power?![]()
Tbf it is pretty short sighted to be baffled as to why folk would want to move cars with no power.Why would you want to move a car with no power?
honestly it’s just tripe that comes out your mouth. No one needs a smartypants inventing stuff.
To move it to a safer location. To recover it. To prevent it being a hazard.
with no power how did it get applied to prevent that?
Daily use a bigger cup holder is far more useful than Whatsifs
So you’ll want a new battery then.
next
But the button is an electronic switch. It's still brake by wire, so more likely to fail than the pedal which can still be pressed if you lose power![]()
