Many ethernet leads only 4 port hub ?
25 May 2016
North wales
Hi guys I previously got away with setting up my devices with ethernet cables straight to my bt hub, but now my son has moved back home and took over 2 ethernet ports on the Bt router so the other two available ports has a sky q connection and that leaves one left but here is the problem, I have a gaming pc, ps5 and a Xbox series x so 3 doesn’t go into one, I have heard about ethernet switches but also heard about them interfering with the router with occasionally restarting hubs or not working, what do you guys do for situations where you have many devices that need to be wired to the hub but not enough ports ? Don’t really want to use wifi with devices that need fast connection all the time.
lol at the 10/100 switch, never knew they still did them.
OP - just get any unmanaged gigabit switch, 8 port will be fine and give you some spare. You just need to plug an ethernet cable into any of the ports on the new switch and the other end into your router. You can then plug everything else into the switch (or leave some in the router if you wish but I would generally remove everything in the router apart from the link to the switch personally) and have everything plugged into the switch directly.
Sorry guys abit of a novice regarding which switch is needed, all I know is my maximum download speed I can get is around 60mb if that helps ?
Thankyou for all your helpfull replies, so the best option is to takeout all ethernet cables that are in the router and put them all into a switch which leaves just the switch cable occupying only one ethernet port on the back of the hub ?
^^^ Exactly.
The term Hub is a bit out of date. Hubs send all network data to all ports. Technically your router is still a switch.
Switches will separate the network packets more so each port receives the intended data put simply.
Tbf I didn't notice it was a 10/100 either until after I posted. Almost takes me back to the days of having to check if something was really a switch or a damn hub!
Yeah I still have collision light nightmares :D
Pretty much. You can still use spare ports on your ISP supplied router too. The only thing to bear in mind is do not attach two cables between your router and the switch as this will form a loop. Only ever use a single cable.
Hi guys have the tp switch coming today, does the main plug from the switch need to be plugged into the wall like routers to get the maximum power or can they be put into a surge protector block ?
