This might have been a valid point years ago when we had single core single thread cpu's.
Erm....do you think a modern 8c16t cpu is running less than 16 processes at any one time?
No but they certainly aren't all pegged at 100% while playing any games, there's more than enough spare cpu resources to slot in background processes.
And actually that 0.1 microseconds is long time in scale of CPU.Context switches still incur a performance cost - and that occurs twice (once to switch away from your game thread, and again to switch back). Yes it's likely in the order of 0.1 microseconds, but these all add up when contributing to frame times etc.
This is fairly pointless
I do not want big/little cores outside my phone
You would've thought the 12900K should beat AMD's last gen (16 core 5950x), or it would be a bit of a fail.
So you want to see 1000w cooling solutions?
By allowing some parts of the package to use lower powered more efficient cores, it frees up some of the total package constraints to allow the higher performance cores to use extra power and that cooling budget.
I think we'd ideally need to see the difference with both CPUs clocked at say 4Ghz or 4.6Ghz to get a real idea of the performance difference.
The 12900k is 25% faster than the 5950x in single core
https://wccftech.com/intel-core-i9-...nchmarks-faster-than-amd-ryzen-9-5950x-rumor/
benchmark makes no sense at all, even if the single is as powerful as it is, how on earth does it stack up that only 8 cores can pull that amount of multi
