Something else i have found from a few different sources, The Vega 64 work better using 2 separate 8pin power leads rather than a single cable with a splitter. Gonna try that.
To be frank you should have been doing that from the start !
I agree, it should have come like that from the retailer.
That retailer ain't worth a damn if that's how its left them. IIRC that's out of spec for the card as I believe one 8 pin is 150w. Think the cards are rated at 250w ish.
i always knew about the 2 seperate power cables due to places like OC forums
well you would think that, but guess retailers is about selling, very rare some have good after sales, or its mentioned during saleThey own these forums!!!!!
You'd think they would know then.
And, results.....?
Got nearly 2 hrs of RB6 before it black screened. Temps were at most mid fifties and overall a lot cooler that before.
Next need to try and work out under-volting to see if that helps.
Check the temps in hwinfo64 for GPU, hotspot and VRM1 and VRM2.
If they are all in check (VRM 1/2 < 70C, Hotspot < 90C, GPU <80C), then the card is probably dying (HBM most likely).
My Vega 64 died the same way. Except first the FPS started momentarily dropping to 15 fps in Fortnite before going back to 120. Then eventually it just black screened. Then worked for one more day, then black screened then after another reset there were color bars in the BIOS and that's all she wrote.
Sold it for parts/not working for $250 USD on the bay.
ive seen folk over that hotspot, i thought throttling began around 95,i could be wrong but sure i read was around that, though have seen over 100 with folk reporting no issues, my nitro hotspot was in mid 80's iirc when overclocking, though i was quite a bit higher than those settings
