***The High-Res Screenshot Thread!***
Are you using any mods Gerardfraser? nice screenshots
Agreed - I actually thought someone had cheated and posted some photos at first glance! The last three screenshots are amazing.
Yes I am actually, using the reshade with RTGI shader and a weather mod I made from cheat mod for changing weather and clouds from stormy to sunny.
Weather Mod- https://www.nexusmods.com/kingdomcomedeliverance/mods/1193
A repository with thousands of pre defined color presets for ReShade https://github.com/TheGordinho/MLUT
Reshade https://reshade.me/
RTGI Raytracing by PascalGlitcher https://www.patreon.com/mcflypg
If you look you can find RTGI for free,if you look. Does it drop FPS sure does but you can adjust effects to lessen FPS loss. For the screens 50FPS loss so running the game at around 80FPS-100FPS average.
Video that shows FPS while running
Playing a few different games at the moment
Farming Simulator 19
Totalwar: Warhammer 2
Gunfire Reborn
Two Point Hospital
Cyberpunk 2077
What hardware and settings are you using? I can't seem to run the game on anything above medium without taking a massive fps hit.
Now with the RTGI shader expect to lose 50FPS-60FPS that is just the way it is. I read your sig you did not list a video card so you will have to try different setting in the advanced menu for FPS increase.With the mods below menu settings are not original.
With that said video 30 minutes with average of 80FPS-100FPS and 1%low hit 78FPS so extremely playable.
I use mods I put together for visuals of higher than ultra settings with good FPS.
Download- I separated some mods so not to be confusing with people unfamiliar with KDC mods,with custom clothing textures and a way to edit the armor stats in a read me. If you just want the FPS increase only, you will lose the ability to change weather,time etc on the fly.
https://drive.google.com/file/d/1LhM0m9lLjLLLoc49-9XVsctQf3vMCWKv/view?usp=sharing
Extract files to and for FPS increase only keep folders below: - D:\Steam\steamapps\Common\KingdomComeDeliverance
Data
Engine
Mods- delete all but FlowgraphHook,Optimized_Graphic_Presets for FPS only(the graphics preset is just basic edition without the bells and whistles)
The computer I used for that video posted
♦ CPU - Intel 10850X With MasterLiquid Lite ML240L RGB AIO
♦ GPU - Nvidia RTX 3080
♦ RAM - G.Skill 32 GB DDR4 (CL17 4400Mhz)
♦ Mobo - Asus Tuf Gaming Wifi (BIOS 2401)
♦ SSD - NVME SSD 1TB
♦ DSP - LG B9 65" 4K UHD HDR OLED G-Sync Over HDMI
♦ PSU - Antec High Current Pro 1200W
@humbug @ne0
Why is it so hard for those that post their screenshots not to type in the title of the game as well ?? :confused:
Sorry I didn't see those rules. Typing in the title of the game is kind of a natural thing to do if you think about it but won't do it again.
/edit oh wait...you want the title of the game in the post? I've completely misunderstood. In fact, I did put the title of the game in the post originally but had some issues posting and ended up deleting it. Will put it back.
Are those mods you are using or in game cars/ locations?
Supra, RX7 and Skyline are in game. Locations are driveable, ones in shot are Pudsey and Musek I think it is. I have a vid up on my channel of Pudsey. I'll post in the AC thread for yiu so it's easy to find. Just a note I do run lots of mods, Content Manager, Custom Shader Patch, SOL 2.1.3 ETC. If you're interested I do have installation guides on my channel which you should find easily if you need.
Amazing thanks Ill take a look thanks. Yeah sure been wanting to get into AC for ages.
