It's been the next day a couple of times, it was when I got my 3080FE last drop.Seems everyone else has a had a drop today, be interesting to see if the UK get blessed this week!
Those are good temps. My 3080 runs hotter than yours and I have done the thermal pads mod.What temps are people getting on their 3080ti? I've upgraded from a 3070.
Undervolted to 1750 + 800.
Getting memory 80-83, hotspot 75-77, gpu 65-68 when stressed.
Performance is still better than stock on 3dmark.
Not the best case and my ventilation could be better.
It completely depends what game and frame rate you are playing at.
I can play overwatch at 4k 120hz at 40c but you play something like cyberpunk or red dead maxed out at 4k 120hz for a few hours they are going to start pumping out serious heat.
It helps to turn case fans up a bit to keep them running cool. I always just set power target maxxed out and set target temp to 69c to stop it throttling.
Does lowering the target temp increase fan speed or lower clocks/voltage to achieve that
Pretty sure it starts lowering clocks/voltage. But not very agressively in my experience, so temp can actually creep significantly higher that your threshold.Does lowering the target temp increase fan speed or lower clocks/voltage to achieve that
Does anyone know if all FE cards coming are now LHR or not
Does anyone know if all FE cards coming are now LHR or not, I like to use my PC for gaming and mining if possible
To answer the question, I think only 3090's are going to be guaranteed normal cards that can mine. However, as ETH moves to PoS in a few months I cant see it being a thing for nvidia unless they want to waste time/resources into algorithm variants available.The Ti's are all LHR so that rules them out.
My Ti isn't LHR..
I've decided to put my 3060Ti into a friends PC and then when the next 3080 drop hits he's going to get me a 3080.
My Ti isn't LHR..
I've decided to put my 3060Ti into a friends PC and then when the next 3080 drop hits he's going to get me a 3080, I'm not in the country until august so gives me a bit of time where it doesn't matter if I have a PC or not..
So, just have to see how long before there's a drop and he can get a card vs how long it takes me to get back home..
Today, we’re taking additional measures by applying a reduced ETH hash rate to newly manufactured GeForce RTX 3080, RTX 3070 and RTX 3060 Ti graphics cards. These cards will start shipping in late May.
@Th0nt the 3060ti I bought around 4 weeks ago wasn't LHR.
The latest Ti's released were the 3070 and 3080..
If your referring to the 3060Ti then that has been out since December and LHR did not phase into manufacturing till early this year. Source: nVidia themselves...
Yes, I was referring to the 3060Ti, as that's what I have, however you misspoke when you said "The Ti's are all LHR so that rules them out." when what you meant was the 'latest' Ti's are LHR..
I also would take the NVidia blog with a pinch of salt as it was also them that said that no FE cards would be LHR, they've obviously changed their mind, but does that mean that early 3060Ti's are fine and after a certain date they become LHR, or no 3060Ti's will ever be LHR, have they actually clarified the position on this since the linked article?!
I think people who have obtained very recent FE's of the 3070/80 would be able to update if they are limited or not.
I thought they had said that no FE cards were going to be LHR, only AIB's, tbh I've kinda given up they change their mind and does anyone really know 'how' they are LHR'ing the cards, is it a BIOS thing, something on the PCB, something on the die, its all a mystery..
But yes, those that have had cards should be reporting if those cards are LHR and what the build date on them is, Ti or not..
